Ok So I upgraded my Frankenso to 20211114 and now my Lambda / AFR no longer works.
I am using a AEM UEGO sensor connected via CAN
https://www.aemelectronics.com/products/wideband-uego-air-fuel-controllers/x-series-inline-wideband-uego-afr-controller
Sensor works on 20210516 No issues:
Log file: https://www.rusefi.com/online/view.php?log=479
Sensor no longer works on 20211114
Log file: https://www.rusefi.com/online/view.php?log=480
Latest tune I am using:
https://www.rusefi.com/online/view.php?msq=761
Did I do something wrong?
Frankenso AFR / Lambda not working over can bus after 20210909
Re: Frankenso AFR / Lambda not working over can bus after 20210909
per slack discussion:
Set debug mode to "CAN"
got log from RUS EFI console.
(Engine was NOT running at time of log)
2021-12-06_20_19_49_731: ConsoleUI: COMPOSITE_OFF_RPM=300
2021-12-06_20_19_50_915: EngineState: initHardware()
2021-12-06_20_19_50_916: EngineState: led: CRITICAL status on PD14
2021-12-06_20_19_50_917: EngineState: initRtc()
2021-12-06_20_19_50_918: EngineState: engine chart: No
2021-12-06_20_19_50_919: EngineState: engine chart size=0
2021-12-06_20_19_50_948: EngineState: USB DM on PA11
2021-12-06_20_19_50_949: EngineState: USB DP on PA12
2021-12-06_20_19_50_953: EngineState: *** rusEFI LLC (c) 2012-2021. All rights reserved.
2021-12-06_20_19_50_954: EngineState: *** rusEFI v20211114@33751
2021-12-06_20_19_50_955: EngineState: *** Chibios Kernel: 6.1.3
2021-12-06_20_19_50_955: EngineState: *** Compiled: Nov 14 2021 - 22:00:16
2021-12-06_20_19_50_964: EngineState: *** COMPILER=9.3.1 20200408 (release)
2021-12-06_20_19_50_965: EngineState: *** detected HSE clock 7.97 MHz PLLM = 8
2021-12-06_20_19_50_966: EngineState: UID=23004D 34375114 32333734
2021-12-06_20_19_50_966: EngineState: MCU rev=413 flashSize=1024
2021-12-06_20_19_50_973: EngineState: CORTEX_MAX_KERNEL_PRIORITY=2
2021-12-06_20_19_50_975: EngineState: STM32_ADCCLK=21000000
2021-12-06_20_19_50_976: EngineState: STM32_TIMCLK1=84000000
2021-12-06_20_19_50_977: EngineState: STM32_TIMCLK2=168000000
2021-12-06_20_19_50_979: EngineState: STM32_PCLK1=42000000
2021-12-06_20_19_50_980: EngineState: STM32_PCLK2=84000000
2021-12-06_20_19_50_989: EngineState: PORT_IDLE_THREAD_STACK_SIZE=32
2021-12-06_20_19_50_991: EngineState: CH_DBG_ENABLE_ASSERTS=1
2021-12-06_20_19_50_992: EngineState: CH_DBG_SYSTEM_STATE_CHECK=1
2021-12-06_20_19_50_993: EngineState: CH_DBG_ENABLE_STACK_CHECK=1
2021-12-06_20_19_50_994: EngineState: EFI_LOGIC_ANALYZER=1
2021-12-06_20_19_50_995: EngineState: EFI_TUNER_STUDIO=1
2021-12-06_20_19_51_005: EngineState: EFI_SIGNAL_EXECUTOR_SLEEP=0
2021-12-06_20_19_51_006: EngineState: EFI_SIGNAL_EXECUTOR_HW_TIMER=0
2021-12-06_20_19_51_007: EngineState: EFI_SHAFT_POSITION_INPUT=1
2021-12-06_20_19_51_009: EngineState: EFI_INTERNAL_ADC=1
2021-12-06_20_19_51_010: EngineState: readFromFlash 80E0000
2021-12-06_20_19_51_016: EngineState: applyNonPersistentConfiguration()
2021-12-06_20_19_51_017: EngineState: initializeTriggerWaveform(TT_TOOTHED_WHEEL_36_2/48)
2021-12-06_20_19_51_019: EngineState: index=0 NaN gap
2021-12-06_20_19_51_030: EngineState: TRG rpm=0 time=0 eventIndex=2 gapIndex=0: gap=2147483647.647 expected from 2.250 to 3.750 error=No
2021-12-06_20_19_51_032: EngineState: index=1 NaN gap
2021-12-06_20_19_51_103: EngineState: 0 - unix time
2021-12-06_20_19_51_107: EngineState: Current RTC localtime is: 2021-12-06 20:19:50 w=1
2021-12-06_20_19_51_108: EngineState: confirmation_set date 1638821990:19
2021-12-06_20_19_51_110: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_51_182: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_51_259: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_51_260: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_51_376: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_51_377: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_51_493: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_51_494: EngineState: CAN_rx 180 384 8 53 79 29 31 77 56 92 6
2021-12-06_20_19_51_607: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_51_608: EngineState: CAN_rx 180 384 8 53 58 29 20 78 57 92 6
2021-12-06_20_19_51_709: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_51_710: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_51_803: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_51_933: EngineState: CAN_rx 180 384 8 53 48 29 18 78 56 92 6
2021-12-06_20_19_52_037: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_52_153: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_301: EngineState: CAN_rx 180 384 8 53 48 29 18 78 56 92 6
2021-12-06_20_19_52_305: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_52_306: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_307: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 56 92 6
2021-12-06_20_19_52_409: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_52_478: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_479: EngineState: CAN_rx 180 384 8 53 69 29 29 77 56 92 6
2021-12-06_20_19_52_480: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_52_580: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_581: EngineState: CAN_rx 180 384 8 53 58 29 20 77 56 92 6
2021-12-06_20_19_52_700: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_803: EngineState: CAN_rx 180 384 8 53 48 29 18 78 56 92 6
2021-12-06_20_19_52_804: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_52_942: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_53_048: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_049: EngineState: CAN_rx 180 384 8 53 48 29 18 78 57 92 6
2021-12-06_20_19_53_132: EngineState: CAN_rx 180 384 8 53 48 29 18 77 57 92 6
2021-12-06_20_19_53_133: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_295: EngineState: CAN_rx 180 384 8 53 38 29 10 77 56 92 6
2021-12-06_20_19_53_297: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_376: EngineState: CAN_rx 180 384 8 53 58 29 20 78 57 92 6
2021-12-06_20_19_53_377: EngineState: CAN_rx 180 384 8 53 48 29 18 78 57 92 6
2021-12-06_20_19_53_496: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_588: EngineState: CAN_rx 180 384 8 53 38 29 10 78 57 92 6
2021-12-06_20_19_53_589: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_735: EngineState: CAN_rx 180 384 8 53 58 29 20 78 57 92 6
2021-12-06_20_19_53_737: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_53_792: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 57 92 6
2021-12-06_20_19_53_945: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_024: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_025: EngineState: CAN_rx 180 384 8 53 69 29 29 78 57 92 6
2021-12-06_20_19_54_142: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_406: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_408: EngineState: CAN_rx 180 384 8 53 CB 29 5B 78 57 92 6
2021-12-06_20_19_54_410: EngineState: CAN_rx 180 384 8 53 89 29 3A 77 57 92 6
2021-12-06_20_19_54_529: EngineState: CAN_rx 180 384 8 53 38 29 10 78 57 92 6
2021-12-06_20_19_54_531: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_54_533: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_535: EngineState: CAN_rx 180 384 8 53 79 29 31 78 57 92 6
2021-12-06_20_19_54_631: EngineState: CAN_rx 180 384 8 53 48 29 18 77 56 92 6
2021-12-06_20_19_54_632: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_714: EngineState: CAN_rx 180 384 8 53 9A 29 42 78 56 92 6
2021-12-06_20_19_54_715: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_54_716: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_54_929: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_012: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_55_014: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_155: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_397: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_398: EngineState: CAN_rx 180 384 8 53 38 29 10 77 56 92 6
2021-12-06_20_19_55_480: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_55_481: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_623: EngineState: CAN_rx 180 384 8 53 58 29 20 77 56 92 6
2021-12-06_20_19_55_625: EngineState: CAN_rx 180 384 8 53 17 28 FF 78 56 92 6
2021-12-06_20_19_55_626: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_55_628: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_55_629: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_751: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_55_754: EngineState: CAN_rx 180 384 8 53 38 29 10 78 56 92 6
2021-12-06_20_19_55_755: EngineState: CAN_rx 180 384 8 53 9A 29 42 78 56 92 6
2021-12-06_20_19_55_756: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_55_832: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_55_832: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_55_833: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_55_977: EngineState: CAN_rx 180 384 8 53 89 29 3A 77 56 92 6
2021-12-06_20_19_55_979: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_099: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_56_101: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_206: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_56_207: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_56_250: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_251: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_56_393: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 55 92 6
2021-12-06_20_19_56_394: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_395: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_56_473: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_56_474: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_56_474: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_56_474: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_56_475: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_594: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 55 92 6
2021-12-06_20_19_56_595: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_56_695: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_846: EngineState: CAN_rx 180 384 8 53 9A 29 42 78 55 92 6
2021-12-06_20_19_56_848: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_56_849: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_850: EngineState: CAN_rx 180 384 8 53 CB 29 5B 78 55 92 6
2021-12-06_20_19_56_852: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_56_961: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_56_962: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_56_963: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_57_031: EngineState: CAN_rx 180 384 8 53 48 29 18 78 55 92 6
2021-12-06_20_19_57_032: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_57_170: EngineState: CAN_rx 180 384 8 53 AA 29 4A 78 55 92 6
2021-12-06_20_19_57_171: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_57_172: EngineState: CAN_rx 180 384 8 53 BB 29 53 78 55 92 6
2021-12-06_20_19_57_251: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_57_252: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_57_252: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_57_253: EngineState: CAN_rx 180 384 8 53 48 29 18 78 55 92 6
2021-12-06_20_19_57_253: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_57_391: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_57_392: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_57_480: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_57_588: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 55 92 6
2021-12-06_20_19_57_589: EngineState: CAN_rx 180 384 8 53 48 29 18 78 55 92 6
2021-12-06_20_19_57_724: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_57_847: EngineState: CAN_rx 180 384 8 53 9A 29 42 78 55 92 6
2021-12-06_20_19_57_849: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_57_955: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_57_956: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_58_149: EngineState: Sending CAN message: SID 0/2 7A 0 0 0 0 0 0 0
2021-12-06_20_19_58_152: EngineState: CAN_rx 180 384 8 53 79 29 31 78 55 92 6
2021-12-06_20_19_58_256: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 55 92 6
2021-12-06_20_19_58_257: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_58_366: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_58_368: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_58_614: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_58_616: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_58_617: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_58_619: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_58_677: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_58_796: EngineState: CAN_rx 180 384 8 53 89 29 3A 78 55 92 6
2021-12-06_20_19_58_796: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_58_892: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_005: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_59_006: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_59_139: EngineState: CAN_rx 180 384 8 53 58 29 20 78 55 92 6
2021-12-06_20_19_59_140: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_142: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_59_275: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_277: EngineState: CAN_rx 180 384 8 53 48 29 18 78 55 92 6
2021-12-06_20_19_59_388: EngineState: CAN_rx 180 384 8 53 69 29 29 78 55 92 6
2021-12-06_20_19_59_389: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_490: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_59_491: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_19_59_492: EngineState: CAN_rx 180 384 8 53 CB 29 5B 77 56 92 6
2021-12-06_20_19_59_582: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_59_583: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_726: EngineState: CAN_rx 180 384 8 53 79 29 31 77 56 92 6
2021-12-06_20_19_59_728: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_59_729: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_731: EngineState: CAN_rx 180 384 8 53 38 29 10 78 55 92 6
2021-12-06_20_19_59_813: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_59_814: EngineState: CAN_rx 180 384 8 53 79 29 31 78 56 92 6
2021-12-06_20_19_59_814: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_19_59_814: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_19_59_905: EngineState: CAN_rx 180 384 8 53 9A 29 42 77 56 92 6
2021-12-06_20_19_59_906: EngineState: CAN_rx 180 384 8 53 58 29 20 78 56 92 6
2021-12-06_20_20_00_007: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_20_00_008: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_20_00_008: EngineState: CAN_rx 180 384 8 53 9A 29 42 78 56 92 6
2021-12-06_20_20_00_117: EngineState: CAN_rx 180 384 8 53 69 29 29 78 56 92 6
2021-12-06_20_20_00_118: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_20_00_231: EngineState: CAN_rx 180 384 8 53 58 29 20 77 56 92 6
2021-12-06_20_20_00_231: EngineState: Sending CAN message: SID 0/2 79 0 0 0 0 0 0 0
2021-12-06_20_20_00_232: EngineState: CAN_rx 180 384 8 53 BB 29 53 77 56 92 6
