MRE and EGT option
JRD McLAREN
MRE and EGT option
Post by JRD McLAREN »
Is able make EGT option "visible" in any future release ..?
due to: https://rusefi.com/forum/viewtopic.php?p=43270#p43270
Re: MRE and EGT option
Done
JRD McLAREN
Well 8-)
still waiting for Godot ...
Thanks.
JRD McLAREN
I still can't see EGT option in TS ... :?
(stable 20211114)
What is the relation between "Sun Nov 21" done and 2021-11-14 version?
JRD McLAREN
SORRY ....
I'm an idiot ... ...
JRD McLAREN wrote:
Thu Jan 06, 2022 6:57 pm
SORRY ....
You are in best company here!
JRD McLAREN
..it is thereee..... and IT WORKS ...
JRD McLAREN
I'm got this error ....
it occur when EGT chip SPI & CS pin are selected,
no sensor connected (to MAX31855)
and MRE is conected, or to be connected to TS (via USB or BT)
MRE drop to FATAL, and engine STOP ...
(it is not too safe, when you overtake and something cut EGT senror wire)
klpaul
Post by klpaul »
JRD McLAREN wrote:
Thu Jan 06, 2022 7:47 pm
What version of MRE firmware are you using for EGT to work? I connected MAX31855 to SPI3(PC10, PC11, PC12) and СS(PA 15) and EGT doesn't work.
I am using stm32f405 discovery. If you write the firmware from Frankenso, then the EGT works.
JRD McLAREN
this is for microRusEFI ... not for others ... :roll:
klpaul wrote:
Wed Mar 30, 2022 4:59 am
We disabled it on MRE 🙃 edit: looks like I was even the one who broke it, oops
Will be fixed soon: https://github.com/rusefi/rusefi/pull/4026
JRD McLAREN
..in latest firmware ... ??? :o
That linked pull request will merge some time tomorrow morning (8-12 hours from now), then it will be in the latest snapshot firmware.
JRD McLAREN
I have 20220126 .. and it have EGT option ..
EDITED: but I can't test it at this moment ...
JRD McLAREN wrote:
Wed Mar 30, 2022 7:16 am
Correct, you do have it on 2022 01 26. It was broken after that.
klpaul
Post by klpaul »
mck1117 wrote:
Wed Mar 30, 2022 6:42 am
Thank's mck1117, EGT work.
On one SPI, egt and sd card do not work, either egt or sd card. Can you add the ability to disable flash memory on SPI2 in the TS menu so that you can connect a SD card to SPI2?
The SD card will be on SPI2, and on SPI3 there will be EGT.
klpaul wrote:
Wed Mar 30, 2022 6:06 pm
rusEFI does not use flash memory at all there is nothing to disable.
klpaul
Post by klpaul »
Wed Mar 30, 2022 6:11 pm
Can you Enable SPI2 on MRE in TS? because it doesn't work.
klpaul wrote:
Wed Mar 30, 2022 11:06 pm
please upload your tune to rusEFI online
please provide a URL of the exact dialog where you are failing to make a change
"doesn't work." is vague please use more of technical terms
klpaul
Post by klpaul »
Wed Mar 30, 2022 11:16 pm
SPI_1=true //for TLE8888
SPI_3=true //for SD, EGT and other
SPI_2 none
I want SD card and EGT to work. Because EGT and SD CARD don't work at the same time on SPI3.
board_configuration file
static void setupTle8888() {
	// on microRusEFI SPI3 is exposed on PC10/PC11 and there is interest to use SD card there
	// PB3/PB4 could be either SPI1 or SP3, let's use not SPI3 to address the contention
	// Enable spi1
	engineConfiguration->is_enabled_spi_1 = true;
	// Wire up spi1
	engineConfiguration->spi1mosiPin = GPIOB_5;
	engineConfiguration->spi1misoPin = GPIOB_4;
	engineConfiguration->spi1sckPin = GPIOB_3;
	// Chip select
	engineConfiguration->tle8888_cs = GPIOD_5;
	// SPI device
	engineConfiguration->tle8888spiDevice = SPI_DEVICE_1;
void setBoardConfigOverrides() {
	setLedPins();
	setupVbatt();
	setupTle8888();
	setupEtb();
	engineConfiguration->clt.config.bias_resistor = 2700;
	engineConfiguration->iat.config.bias_resistor = 2700;
	engineConfiguration->canTxPin = GPIOB_6;
	engineConfiguration->canRxPin = GPIOB_12;
	// SPI for SD card
	engineConfiguration->is_enabled_spi_3 = true;
	engineConfiguration->sdCardSpiDevice = SPI_DEVICE_3;
	engineConfiguration->spi3mosiPin = GPIOC_12;
	engineConfiguration->spi3misoPin = GPIOC_11;
	engineConfiguration->spi3sckPin = GPIOC_10;
Sorry do not follow, you've jumped from TS to board file I was not able to follow what leads to what
klpaul wrote:
Thu Mar 31, 2022 12:36 am
why? maybe proper route is to fix this defect in the code?
Thu Mar 31, 2022 12:41 am
btw we made the explicit choice to not support multiple devices per bus to avoid any priority inversion due to locking of the shared resource
klpaul
Post by klpaul »
Okay Andrey, please fix it.
Why is flash memory needed on the MPE board?
JRD McLAREN
Flash memory is not used ..
mck1117 wrote:
Thu Mar 31, 2022 12:42 am
When I'm testing my addon borad, EGT and SDcard woks together on SPI3 bus .. ..
klpaul
Post by klpaul »
Make EGT work, again it does not work on the latest version of August 12th.
