Hi all,
I have a Frankenso-based board. I've uploaded my latest tune here:
https://rusefi.com/online/view.php?msq=650
When I try to assign an input pin for the Vehicle Speed Sensor input, I get an error that says "ICU already used VSS 202110719@source". In the Speed Sensor configuration menu, I see that the "Vss Car Type" is set to "BMW_e46", and is grayed out. How do I go about setting up the VSS input correctly?
Regards,
Parag
Settings configuration error: VSS already configured.
Re: Settings configuration error: VSS already configured.
Correct. Tune says rusEFI 2021.07.18 which is before disabling the joystick but after making VSS conflict with joystick. Software version would need to move either forward or backwards.
The safer option would be to disable individual joystick pins in configuration without touching firmware version.
Thanks, @mck1117 and @AndreyB. But I have the Joystick pins already disabled (center, button A, B, C, D all set to NONE).
I can try to use the latest build from 2021.09.20 to see if that resolves the issue.
