Custom board base on Proteus Software trouble
hugovw1976
- Github Username: hugovw1976
I made my custom board base on Proteus:
Just with a few outputs omitted (only one electronic throttle body, only 12 Low-Side outputs).
I compile the proteus firmware for F4 without changes, I test all output and inputs and all works fine except for analog input 1, I have this error: Someone know how can I fix this.
JRD McLAREN
Re: custom board base on Proteus
...you can use PC0 pin twice...
Check your configuration, change it, and restart ECU
is this remark on your github still valid?
Please do not use the gerber files, the board is not tested yet! P&P file not tested on JLC PCB (Board is hand soldering)
hugovw1976
I know, but I don't know why say pin pc0 is used by HIP9011 where can disable HIP9011 I don't have any.JRD McLAREN wrote: ↑Wed Aug 18, 2021 7:35 am...you can use PC0 pin twice...
hugovw1976
Re: Custom board base on Proteus Software trouble
may be that was preset for proteus? try disabling hip in tuner studio?
if it is not a secret, what was the production cost per one unit and how did you cope with chip shortage? soldered it on your own?
hugovw1976
In Tuner Studio don't have any option for dissable HIP9011. I Still need to check all component prices but about $250 per unit. The mos dificult to find was STM32F407ZGT6, I order some Develomped Board from Aliexpress and desolder chips. I use stencil and a reflow oven to solder front components and the back components solder by hand.
isn't it in Controller menu?
Did you really build proteus firmware? You mention F407, but the proteus firmware image requires F427/9 for the extra memory.
Please provide much more details. Please spell out how exactly have you build. please spell out why do you need to build at all not use one of official binaries.
hugovw1976
In tuner studio I don't have thath menu the knock menu is diferent I think because proteus don't use HIP9011 for knock, proteus have two inputs for knock. I don't know why say PC0 is used by HIP9011
hugovw1976
In topic Proteus - Waterproof, High-feature ECU I ask if I can use STM32F407ZGT6 instead of STM32F429GT6 and AndreyB say YES.
I clone https://github.com/rusefi/rusefi.git and in folder rusefi/firmware7config/boards/proteus I run the !compile_proteus_f4.bat and compile for f4 I upload the rusefi.hex file created in rusefi/firmware/build folder to my board. and all inputs and outputs work fine except for analog1 (PC0) because is used by HIP9011 but proteus dont have HIP9011
hugovw1976
I made my board based on proteus schematics the STM32 chip is pin to pin compatible from proteus to my board just with some pins I don't use because I don't have 16 low side driver just 12, only one drive by wire and thath it's all other pins are the same.
I don't use official binaries because I modify the Haltech can communication because some of the channels proteus send I send them by another module (like Wheel speed). I made a custom module for 4 VR speed sensors and send those values over can bus to my datalogger display. And if this module and the ECU try to send the same channel it's a conflict.
why not make a pull request to get that in to the official firmware?hugovw1976 wrote: ↑Thu Aug 19, 2021 1:51 amI don't use official binaries because I modify the Haltech can communication because some of the channels proteus send I send them by another module (like Wheel speed). I made a custom module for 4 VR speed sensors and send those values over can bus to my datalogger display. And if this module and the ECU try to send the same channel it's a conflict.
hugovw1976
I try official firmware but the last it's supported by STM32F407ZGT6 is 2021_05_04, new ones doesn't work I believe it because the ram memory (192 vs 256 KB).mck1117 wrote: ↑Thu Aug 19, 2021 2:01 amwhy not make a pull request to get that in to the official firmware?hugovw1976 wrote: ↑Thu Aug 19, 2021 1:51 amI don't use official binaries because I modify the Haltech can communication because some of the channels proteus send I send them by another module (like Wheel speed). I made a custom module for 4 VR speed sensors and send those values over can bus to my datalogger display. And if this module and the ECU try to send the same channel it's a conflict.
Simon@FutureProof
- Slack: Orchardperformance
I believe there are pin compatible stm32 f429 vg that will allow you to use the official firmware.
It might be worth doing a chip swap.
Proteus is intended to work with the larger ram on the 429 VG chips due to the number of features on the proteus.
yes, all 144 pin f407/427/429/f767/h743 are pin compatibleOrchardPerformance wrote: ↑Sat Oct 23, 2021 8:05 pmI believe there are pin compatible stm32 f429 vg that will allow you to use the official firmware.
