Liquid Pressure/Temp combined Sensor
Liquid Pressure/Temp combined Sensor, 10 bar & 140 deg C
0 261 230 340
Description
- Combined Temperature and Pressure sensor. 2x Sensors in one..!!
- 0 - 10.0 bar (145psi) Pressure Sensor for liquid
- -40 - 140 deg C Temperature sensor for liquid
- Bosch Trapez 4-pin connector
- 45degree cone seat, M10x1 fitting
- Suitable for Diesel, gasoline, water, engine oil, transmission oil
Data Sheet_70496907_Pressure_Sensor_Combined_PST-F_1.pdf
Offer Drawing_254101899_Pressure_Sensor_Combined_PST-F_1.pdf
Mating Connector, 5-pin Trapez F 02U B00 751-01
Re: Liquid Pressure/Temp combined Sensor
Technical Specifications
For temperature measurement please use a pull-up resistor with an optimal value of 4.6 kOhm.
The sensor has a protection for overvoltage, reverse polarity and short-circuit.
Connectors and Wires
Bosch Trapezoid
Mating connector
F02U.B00.751-01
Pin 2 Pressure Signal
Pin 3 Power Supply
Pin 4 Ground
Pin 5 Temperature Signal
it should be the same sensor but under a different part number
i buy in mazda dealerships 84$
ASTON MARTIN HY539G756AA
BOSCH 0 261 230 340
BOSCH DS M1 TF
FISPA 84.387
HOFFER 7472385
MAZDA PY8V-18-541B
MCLAREN 13F0517CP
MEAT & DORIA 82385
METZGER 0906191
PORSCHE 9A1 606 203 00
SIDAT 84.387
WE PARTS 410590179
WILMINK GROUP WG1409271
Connector
VW Audi 1 928 405 159 (Inject Sensor)
Ford 1928405159
