Frankenso pcb lcd display
Locked
jaguarman
Post by jaguarman »
The Frankenso pcb the lcd display is not working, That is to say there two lines of white square blocks
If you look at the data pins on the display there is no data.
How can i test the system
Re: Frankenso pcb lcd display
This was resolved two days ago https://github.com/rusefi/rusefi/pull/2576 you need fresh nightly build https://rusefi.com/build_server/rusefi_bundle.zip
jaguarman
Post by jaguarman »
The lcd display is working which good.
But the ttl port does not work
Tuner Studio reports invalid data received from controller
Help
Subject "Frankenso pcb lcd display"
LCD works now, this thread is now locked. In case of any other non-LCD issues please start a new thread.
Locked
