Does anyone know part number of this Mercedes connector? Is it available new? How much is a cheap used ECU to take apart?
https://github.com/rusefi/rusefi/issues/1674
128/145 pin breakout board Mercedes, also PnP ECU
- md_sanci
- Github Username: shadowm60
- Slack: Alex M
- Contact:
Re: 128 pin breakout board Mercedes
It looks like it is a Bosch connector.
The smaller pins distance is the traditional 2.54 mm pitch 2 in a row.
The bigger pins are used in other ECU connectors as well i presume for higher current so it can be constructed from smaller connectors.
My plan was to do this on a test pcb and connect it to the MRE harness, actually i already did it, but is to Maad Max style ) and i would not drive with that.
- IMG_20200806_221435.jpg (384.71 KiB) Viewed 6410 times
- IMG_20200806_221359.jpg (675.12 KiB) Viewed 6410 times
- IMG_20200806_221350.jpg (526.79 KiB) Viewed 6410 times
- IMG_20200806_220900.jpg (433.56 KiB) Viewed 6410 times
so 1264488241 and we need to find cheapest junk yard option
eBay has many 023 545 97 32 for under $20 shipped
Dave says it took him 15 minutes to dissolved with Pace SX100 magic machine - that's about $300 of magic.
- 145_dissoldered.jpg (3.67 MiB) Viewed 6202 times
Jared, your drawing on the connector is amazing - all the pins have aligned just fine!
Jared, your drawing on the connector is horrible you forgot to include two white pivot pins! Any chance you can add those onto the drawing?
https://www.ebay.com/itm/333791544427
- s-l1600 (1).jpg (134.92 KiB) Viewed 5842 times
Let me just leave this here
- 20201231_144015.jpg (913.05 KiB) Viewed 5684 times
- 20201231_143855.jpg (677.57 KiB) Viewed 5684 times
- 20201231_143850.jpg (620.85 KiB) Viewed 5684 times
- 20201231_143833.jpg (672.89 KiB) Viewed 5684 times
- 20201231_143840.jpg (465.23 KiB) Viewed 5684 times
Open question what is the best term for this connector
On the one hand we have technical drawing which shows 8+4+40+24+48+21=145 pins
On the other hand in reality it seems to always be 23 pin in "C" section so 8+4+23+24+48+21=128
At least both 4 cylinder and 6 cylinder ECU I have in my collection have same 23 pin "C" section.
- 20210102_123336.jpg (948.69 KiB) Viewed 5667 times
- 20210102_123138.jpg (1.44 MiB) Viewed 5667 times
Re: 128/145 pin breakout board Mercedes, also PnP ECU
Let's reuse same topic for PnP discussion within Hellen One platform https://rusefi.com/forum/viewtopic.php?f=4&t=1913
Damn this 2003 C200 compressor uses different connector, it uses 4 out of 5 section on the 134 is not that an M111 engine? is that vehicle just a bit too new?
- IMG_20210529_135130.jpg (1.54 MiB) Viewed 4952 times
