[info] rusEfi Scheduler Performance & Accuracy
ptnicu
Re: [info] rusEfi Scheduler Performance & Accuracy
Post by ptnicu »
Gepro wrote:
Sun Nov 15, 2020 10:56 am
If CPU is busy, is it possible to put 2 STM32 by ECU ? They are cheap, and some values can be send via canbus, I don't know how many resources take canbus, but there is not a lot of important value.
The CPU is not busy. If it can do this https://youtu.be/7yXxhvKmVb0 it should generate ignition timing without a glitch, and a lot more.
Multi-core system present other challenges, add complexity not needed to the system.
The RAM consumption is at critical level. There should be some optimization in that area.
Those that know, do. Those that understand, teach.
Aristotle
Gepro
Post by Gepro »
Okay :D
Thanks,
There is some H7 without dual core and with a lot of ram.
I see that microrusefi come back from F7 to F4, i don't know why, but the ram is the same, so the frequency is certainly useless.
The power of a stm looks completely crazy compared to others.
And the frequency of an engine is stupidly slow, a V12 does 6 sparks by turn, so at 10 000RPM it does 1000 sparks by second, that's is only 1KHz...
I am certainly wrong to compare this, but I'm not a software guy.
That is really nice mck1117 ! Great job <3
My preference would be to pause the discussion here until more participants have a chance to contribute their first code pull request :)
mk e wrote:
Sun Nov 15, 2020 2:55 pm
5800(rpm)=96.667(rps)=0.0348(deg/usec)
.0348(deg/usec) x 2.3(usec) =.08 (deg), twice as good as you're claiming and quite excellent!
Are there some points hiding further to the right? Or is my math wrong?
there are a few points down in the tail:
But you're correct, 99.8% of all measured samples were in a 0.1 degree wide window, with only 0.22% outside, the worst of which was 0.16 degree later than the earliest.
