[info] Feature Requests - Feature Bounty Program
- Zeiss
- Github Username: HeinrichG-V12
Re: Feature Requests - Feature Bounty Program
@Andrey and Matthew:
I would put $300 bounty at https://github.com/rusefi/rusefi/issues/3680
Plus:
– possibility to increase idle RPM, i.e. when AC is on
– possibility to temporary (depends of input state) increase RPM, I.e. when trany engages the gear ( change from N to D). It is something for Lua?
Thank you guys!
Plus:
Thank you guys!
Automatic or manual sync?Zeiss wrote: ↑Mon Aug 22, 2022 6:13 pm@Andrey and Matthew:
We already support adding more air, but not adding target RPM. Trivial enough to add.
I think we've already had other asks for P/N vs D idle control, so this is indeed one worth doing. You could also do it with Lua, but it seems like a common enough ask.
- Zeiss
Automatic, of course. Or a mix? Initial sync manual and then a kind of „keep air masses in sync“? Two MAFs and then balance the air mass, when the engine is warm and is idling, like the implementation of BMW/Bosch.mck1117 wrote: ↑Mon Aug 22, 2022 6:16 pmAutomatic or manual sync?Zeiss wrote: ↑Mon Aug 22, 2022 6:13 pm@Andrey and Matthew:
This sounds very good! Something like „AC off = 600 rpm idle, AC on = 750 rpm idle“.
Sounds very good! I think, here are two features. First one is „change from P/N to D“ (increase RPM) and the second one is „reduce torque during gear change“. BMW achieve this by retarding the ignition.
- Zeiss
Perfect!
Where can I find this in TS.
- Zeiss
Thank you!
So, then $300 for trany stuff and ETB sync.
Top-right corner of TS has search control! Took me 8 years to find out about that search feature. One day we shall add it on the rusEFI Online
I would love to pay $2000 for https://github.com/rusefi/rusefi/issues/4195
Just made a skeleton of unit test https://github.com/rusefi/rusefi/commit/564cec3ed25ef26625007a366ce1a1417b5c0b53 with some pointers - desired change should definitely include a test and well, not break existing tests
done: https://github.com/FOME-Tech/fome-fw/pull/479AndreyB wrote: ↑Sat Aug 31, 2024 4:20 amI would love to pay $2000 for https://github.com/rusefi/rusefi/issues/4195
Thank you! You should have an email from Zelle!
I would love to pay $1500 for https://github.com/rusefi/rusefi/issues/6223
Something something EMI USB fatal error?
I would love to pay $300 not even for a fix but just for reproducible steps for getting any official rusEFI board hang up similar to https://github.com/rusefi/rusefi/issues/4310
