I've decided to play with the Mini. https://github.com/rusefi/rusefi/wiki/Mini-Cooper-2003
First step - minimalistic harness extension:
2003 Mini Cooper
2003 Mini Cooper
Re: 2003 Mini Cooper
The stock ECU is definitely confused, but that's OK for now. Coolant temp sensor is not connected, CAN bus is not connected. Weird that it would not rev even while I believe I've connected throttle pedal (that's 6 wires) and electronic throttle body (that's 7 wires) - I guess it has decided to go into limping mode.
Next step: adding a T-junction and sniffing camshaft sensor.
Crank on top, cam on the bottom:
CAN bus notes see https://rusefi.com/forum/viewtopic.php?f=5&t=473
camshaft sensor 5293161aa
https://www.pelicanparts.com/techarticles/MINI_R56/19-FUEL-Crankshaft_Position_Sensor_Testing/19-FUEL-Crankshaft_Position_Sensor_Testing.htm
Pin 1: 5 volts, (yellow arrow)
Pin 2 Ground (green arrow) around zero volts
Pin 3, sensor signal, zero or 12 volts. (red arrow)
I am experimenting with Proteus + Mini Cooper cam sensor on the bench just to gain experience with Hall on the bench.
I have digital power supply feeding 5v into cam sensor and Proteus powered only by USB.
With this specific cam sensor my Rigol shows some massive noise, right? Why is that?
Also fun: standby it shows 1v and with metal flying close by it goes closer to 0v or maybe 0.2v, either way Proteus would not detect that as logic level change right? So how would one read such a cam?
Is anything wrong with my bench setup approach?
- is-that-noise.jpeg (177.65 KiB) Viewed 2410 times
- cam-big-picture.jpeg (149.61 KiB) Viewed 2410 times
Norman says "1k pull-up to 5v" but that made matters worse: same 1v stand-by but now no going to lower level when I wave metal.
