Hey there everyone been a while since we updated our Proteus boards. I don't loaded the latest RusEFI update for the Proeus V4 board did the update and now I can't throttle.
Symptoms: Throttle pedal gauge moves in Tuner studio, and I can calibrate ETBs and they move, TPS 1 and 2 gauges are moving during calibration no issue. But if you press the throttle the ETBs don't move. The car idles fine when started.
My previous firmware was from 2 years ago, and it was working fine, not sure what has changed to disconnect the connection from pedal to ETB?
No throttle to ETB connection after RusEFI update
Lambo97
Re: No throttle to ETB connection after RusEFI update
Need tune and log.
Lambo97
Ney Andrey, what items should we be graphing in the data log?
I assume that for anyone to help more data wiuld be needed, please consider sharing your tune and probably log. Discord chat like mentioned on wiki is another possibility.
Lambo97
I'm not familiar with logging. I'll post my how do I setup RUsEFI logging items in the discord. See if I can setup the logging correctly.
Lambo97
The car is disabled so It's probably better I give up and go back to the old tune and never update. Thanks, I'm done with no support.
