pins that do not exist, or do not work
mak_paint
hello everyone, my name is Alberto Midian, i'm new to the rusefi world, i want to thank you all in advance for your help and i would like to ask a question, i have an experimental board with the 32f407vgt6 chip, i'm trying to create an uaEFI ecu, and i'm playing a bit with tunerstudio, in the output section i see that for the fuel pump relay control output the B16 pin is selected by default, but in the 407vgt6 this pin doesn't exist, and the B8 fan relay pin simply doesn't obey when i press the fan test button, on the other hand the B9 main relay pin does work fine, so i'm confused, what am i doing wrong?... and why aren't there pins B16, B17, B18 on the chip?
Re: pins that do not exist, or do not work
you are confusing stm32 microcontroller pins with pins of uaEFI. uaEFI is a very specific board which you do not have
you want to use 407_discovery firmware not uaEFI firmware
mak_paint
mak_paint
I would like to ask other questions, now I am using the firmware for the discovery board, I don't see how to select the pin for the knock sensor in tuner studio, it only says channel 1 or channel 2, but which pin is it?
