I am currently experimenting with a Mega100 running RusEFI firmware in a Speeduino UA4C. Had the first test drive yesterday, the VE started dialing in with VEAL and target AFR's were getting met relatively quickly. I am still learning the In's & Out's of this system and it's specific tuning procedures, So far I am impressed. I did blow an on-board fuse on the Mega100 and it killed the test drive. Jumpered the fuse with guidance from ggurov. I still need to diag what exactly popped the fuse on the 5v rail. It happened while I was getting comfortable on the test drive and pushed the throttle past 50%, then everything shut down. We are back up and running now and I can continue to test, tune & diag.
However, for your entertainment I'd like to share the build progress on my latest project. Building my 2nd BMW powered T-bucket. The first one has been on the road for just over 3 years and it took 4 years to build. I wasn't planning on building another one but I knew I could do things cleaner and apply all the lessons learned from the first one.
Keep in mind there is nothing traditional about this build, I am putting it together using ideas that are in my head.
...and we are caught up to my current progress on the build. It is still just a bunch of random parts laid out in mock up.
A special thanks to Jhelgesen who made the supercharger adapter on the BMW v8 in build #1. He also made the SendCutSend file for my differential mount perch on build #2. He has also made two sets of intake spacers for my projects, one under the supercharger and the other I can use to adapt over the ITB manifolds for build #2. I think he's made more parts for my projects then I have.
EDIT: Derp, I thought I posted in the "You and your build" section. Mods please move, Thanks!
