[help needed] ETB questions uaefi aircooled vw
Travtech
Hello first post on this forum. New to rusefi not new to engine management systems. Mostly used the megasquirt platform. Anyways I plan to use a uaefi board to run a 2085cc type 1 vw engine with dual 2 barrel drive by wire throttle bodies from an aprilla motorcycle adapted to weber idf manifolds. My question is running 2 etb's do I get tps1 and tps2 singal from only one of the throttle bodies? Or do I wire tps1 to let's say the left tb and tps2 to the right tb? Thanks.
Travtech
Re: ETB questions uaefi aircooled vw
Ok i think I figured out the answer to my question. Just have to use and address two spare inputs as the tps 2-1 and tps2-2. Didnt see the tps drop down menu under the sensors tab.
