Sd Card logging behavior
kneelo
Post by kneelo »
I have a new proteus 0.7 for the race car and looking forward to using the sd card logging.
As i understand it the card doesnt log if theres a usb connection to the ecu. Is there any way to change this behaviour? I have a rpi permanently connected running tuner studio to display the dash. This also has a battery so the rpi is some times connected to the ecu before it gets 12v.
Ideally i am looking for a way to trigger logging to the sd whenever 12v power was applied. I assume this would involve unmounting it as mass storage so the ecu can write to it.
Re: Sd Card logging behavior
Somebody would have to make firmware changes to change the behavior the way you describe
kneelo
Post by kneelo »
Thanks Andrey... Ive tried a few times but this might be excuse I need to get deep enough to understand the firmware code.
