Toyota Supra 2jz-gte non-vvti plug and play uaefi
gurov
Github Username: ggurov
Slack: ggurov
Post by gurov »
it's a carrier board uaefi for the 120 pin non-vvti 2jz found on sc300, aristo, supra
zazzn
Github Username: zazzn
Re: Toyota Supra 2jz-gte non-vvti plug and play uaefi
Post by zazzn »
Wow!!
@gurov Where can I get my hands on one of these boards?
The UAEFI board seems limited on on I/O vs the MS3pro Module which is used in the MS3pro PNP that you had. (I have the same one, and I have another pro PNP for my 7m-gte)
How are you overcoming this? Are you using a can module to add extra I/O if so what are you using?
One thing that isn't clear is just exactly how many inputs are on the UAEFI board. On the webpage it states 2 TPS, 3 Analog Aux 2 analog thermistors
Does that mean that is 7 inputs since TPS is analog anyway on the 2jz along with the IAT, and CLT.
