I see that it has an onboard LSU 4.9 wideband controller. Can this same controller control an LSU 4.2 sensor?
Thanks!
Can the uaEFI control a LSU 4.2 wideband sensor?
Re: Can the uaEFI control a LSU 4.2 wideband sensor?
It depends on what exactly are you asking. Please ask a more specific question.
As is uaEFU supports only 4.9
Someone with relevant skills might be able to make the changes needed for 4.2
Thank you for the info. Was really hoping it would be an easy thing to run the LSU 4.2 sensor with the onboard controller.
Myself and most others have much greater reliability with the 4.2
- Dron_Gus
- Github Username: dron0gus
The only HW difference:
SW supports both sensors on other HW.You do not have the required permissions to view the files attached to this post.
Thank you for the info. Unfortunately, not something I want to play with.
I think I'll just buy this: https://www.shop.rusefi.com/shop/p/dual-channel-wbo
It says that'll control a 4.2 sensor and I'll also be supporting rusEFI a little more.
In the future, I would love to see 4.2 support added to the uaEFI board, even if it costs a little more.
I'm sure most people would like the option to run either sensor as well.
