uaEFI Ultra Affordable EFI
- uaefi-a-back.png (1.54 MiB) Viewed 43320 times
Re: uaEFI Ultra Affordable EFI
Now waiting for wideband cables and pigtails to be manufactured.
Good job! Pretty interesting at this price!
Optional EGR or EGT?
EGT, thank you for pointing out the typo!
it has passed testing https://github.com/rusefi/uaefi/issues/25 and it's now up for sale at https://www.shop.rusefi.com/shop/universal-control-unit
I'm currently following various topics on the forum, and I'm contemplating converting my classic car to run on an ignition-controlled ECU.
Initially, I'll stick with the stock injection system (K-Jet ).
My goal is to maintain the original look of the engine bay, so I plan to adapt the distributor with a trigger wheel.
Is this board suitable for use? I'm not a fan of the connector positions, for me will be better to have all pins on the same side. I might explore changing that.
Thanks for this fantastic project.
uaEFI is doing good! There is already one unofficial adapter see FB group. We've just merged preview of the official hellen-one module for uaEFI adapters see https://github.com/andreika-git/hellen-one/tree/master/modules/uaefi/
Hello I've made a simple box/case and lid with snap fit. It's real simple but should work ok
The board is fastend in with 4 m3 screws directly in the plastic And the lid is as mentioned snap fit, good tight fit so should not come loose.
I've only test printed in petg so I don't know if pla etc would work ( you have to test)
My print settings were
0.16 layer height
3 walls
6 top/bottom layers
0.16 layer height
3 walls
6 top/bottom layers
- rusEFI uafEFI 3dprintbox.rar
- (119 KiB) Downloaded 56 times
- rn_image_picker_lib_temp_021c4e33-e43f-47d3-8bda-7903aa9b5baf.jpg (795.81 KiB) Viewed 31267 times
- rn_image_picker_lib_temp_6fa84de3-4e01-4e9f-812d-bdc78ddc1cb1.jpg (636.11 KiB) Viewed 31267 times
Now working on first official adapter board so rev B had changes specifically for ease of adapter application
Kim has posted another enclosure on FB - https://www.thingiverse.com/thing:6498664
Hi,
2 question 's :
Q1, what is the purpose of the Optional Can 2? or better, when would i need it? any example?
Q2, i recieved my JDY-33 bluetooth, can i just solder it in? or does it need programming first?
thank you.
2 question 's :
thank you.
Q1: I do not know. What's the purpose of CAN 1 or even what's the purpose of rusEFI?
Q2: just updated https://github.com/rusefi/rusefi/wiki/Bluetooth with references to recently updated tickets about all that
Random suggestion while unfortunatelly things are not perfect
- Github Username: ggurov
- Slack: ggurov
- Contact:
more mounting suggestions:
carrier board in a stock ECU case
able to close the cover:
pins into UAEFI molex connectors at almost straight angles:
for molex spacing, 3 pin connectors with middle pin removed:
hello,
what is the copper weight for inner and outer ? both 1oz ?
best regards
best regards
probably, whatever is the default.Atlantis2013 wrote: ↑Tue Apr 30, 2024 11:10 amwhat is the copper weight for inner and outer ? both 1oz ?
default is 1oz for outter and 0.5 for innerAndreyB wrote: ↑Tue Apr 30, 2024 2:21 pmprobably, whatever is the default.Atlantis2013 wrote: ↑Tue Apr 30, 2024 11:10 amwhat is the copper weight for inner and outer ? both 1oz ?
