It has:
4 Audi / VW coils
8 injectors of > 14 ohms
LS engine ETB
a couple of 0-5v pressure sensors
MAP
2 temperature sensors
Main relay
9 relay outputs
2 12v outputs
Tachometer
36-1 Trigger with VR and Hall sensor
10 analog inputs
Trigger simulator.
If it can be of use to you in any way, it is available for development, testing etc
It has an LED light that turns on with ignition output number 1, therefore we can see the synchronization and charging time of the coil in the trigger.
I want to support the project in some way, I don't have much experience in programming but I think I can support at least in documentation.
I am also working on a Dash similar to one I saw on the forum a while ago, it is still in the early stages, as soon as it is more advanced and with better practices for collaboration I will be sharing it with all of you!
