To avoid accidents and damages motor cycles need to have a "safety system" consisting of the follow components
- ignition switch (on or off state)
- engine shut-off (kill) switch (on or off state)
- neutral gear switch (on or off state)
- clutch switch (on or off state)
- side stand switch (on or off state)
- tip-over switch (on or off state)
Only a certain combination of these switches in on or off condition will enable Starter switch to allow for starting engine.
From engine running state any change of this combination must kill a running engine.
1) How would logic for such a "safety system" be implemented (i.e. LUA script)?
None of above mentioned switches is named as such in rusefi/firmware/controllers/sensors/sensor_type.h
2) How would I define these sensors names?
Thanks
Michael
motor cycle "safety system" - how to implement?
mi-hol
- Github Username: mi-hol
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
Michael
Re: motor cycle "safety system" - how to implement?
I'd say two Lua improvement would be needed: auxilary digital inputs (could be hacked with auxilary analog inputs as a work-around) and lua-controller ignition cut similar to current lua-controller ETB disable.
Once those are added, you would read digital inputs and disable ignition per your logic.
Not related to sensor_types.h
mi-hol
Shall I create an issue for this feature?
Best Regards
Michael
Michael
nmstec
OEM bikes: kick stand must be up, or clutch applied to crank. Must be in neutral. Tip over only 85*. Kill switch should kill main ecu power (Unless canbus, in this case shut off fuel pump, injection, and ignition).
"Dave B. 5:03 PM
mi-hol
for "ignition switch (on or off state)" I searched https://github.com/rusefi/rusefi/blob/master/firmware/controllers/lua/generated/value_lookup_generated.md
and https://github.com/rusefi/rusefi/blob/master/firmware/controllers/lua/generated/output_lookup_generated.cpp
and found:
isIgnitionEnabled
Enable ignition - This is default off for new projects as a safety feature, set to "true" to enable ignition and further ignition settings.
but none of the example scripts is using "isIgnitionEnabled".
Any hint where to look?
Best Regards
Michael
Michael
Those are from https://rusefi.com/online/view.php?msq=1349&dialog=injectorConfig and similar ignition dialog.
Tool-tips were wrong I've just wiped those out.
https://github.com/rusefi/rusefi/wiki/Lua-Scripting#getcalibrationname has an example
getCalibration("cranking.rpm")Very limited telepathic abilities - please post logs & tunes where appropriate - http://rusefi.com/s/questions
mi-hol
Apologize, but none of the answers above makes sense to me.
Did you maybe want to reply to a different question ?
Best Regards
Michael
Michael
mi-hol
As the topic was resolved on Slack here is the summary:
the text "isIgnitionEnabled
Enable ignition - This is default off for new projects as a safety feature, set to "true" to enable ignition and further ignition settings."
is plainly wrong and was removed, such a function NEVER existed in LUA
Best Regards
Michael
Michael
mi-hol
Thanks for reply, in the meantime I found that the safety system is actually implemented independent of ECU.
This removed the requirement to implement it via a LUA script.
Best Regards
Michael
Michael
