[help needed] Start but doesn't idle
Noah Levreau
Post by Noah Levreau »
Hi. So I am trying to get my 1990 1.8 swapped miata to run on standalone. The car starts but it wont idle. I think it has something to do with not getting enough fuel.
Here is my tune: https://rusefi.com/online/view.php?msq=1182
It probably is something simple that I overlooked.
Any help will be greatly appreciated since I am at a loss for what to do
Thanks
Re: Start but doesn't idle
Vane door has a mechanical switch to enable fuel pump on NA6 right? Do you have vane door with the switch or did you jump the fuel pump control wire?
BeerMoneyMotorsports
Post by BeerMoneyMotorsports »
Update from Facebook. Car is running with some added fuel. It was going lean(18-20) and dying. Just tuning needed.
