80 amps, and it's designed to be permanently connected directly to the battery anyway
Volvo electric power steering pump CAN bus control
- Zeiss
- Github Username: HeinrichG-V12
Re: Volvo electric power steering pump CAN bus control
@Matthew: Awesome work! Congratulation!
Is there more info about this pump? Pressure for example...
Thank you.
Thank you.
They aren't pressure regulated unless you give it a large volume demand, same as an engine driven pump. The spool valve in the rack normally passes fluid freely, so the pump is moving a large volume at low pressure. If you provide enough resistance to raise the pressure up to the pressure of the bypass valve in the pump, then it is pressure regulated. I think the bypass is at 1100 psi/75 bar or something. During normal steering I never hit the pressure bypass valve unless I hit the stop on the rack.
As far as I can tell, the "speed" limit set over CAN is in fact a current limit on the motor to impose an imaginary "pressure limit" (positive displacement pump so torque ~= pressure).
- Zeiss
Hello Matthew,
thank you for the explanation. A colleague of mine is looking for an electric pump, as a replacement for the servo pump in the 8-series. Our servo pump has a maximum pressure of 120bar. The closest pump we know of is the one from a Mini with 105bar. It is not regulated, knows only on and off.
nmstec
02-05 Mini pumps are not on/off if supplied with LIN data. Working on that slowly. Recommend joining slack.Zeiss wrote: ↑Tue Aug 09, 2022 4:51 pmHello Matthew,
"Dave B. 5:03 PM
- Zeiss
Here you can see the wiring diagram of an 10/2004 Mini Cooper S Convertible:
There is no LIN connected to it.
And here is the picture of the pump:
nmstec
What your diagram isn't showing you, is that the line going to alternator is also going to the ECU. It's linbus. Matt and I figured this out last week. Lin bus control for both pump and alternator.
I'll personally be getting and testing that pump within a month, as I am selling universal EPAS controllers.
"Dave B. 5:03 PM
nmstec
As per Andrey's permission, I now have a solution for running many different types of Steering Assist systems, with a wide variety of modes and functions.
https://www.nmstec.ca/product/psc/
"Dave B. 5:03 PM
