I am concerned that you rarely (never?) post any log files. I believe you do not use automated testing approach either. So, what does "testing" mean _exactly_? Let's please be a bit more transparent about this since some people might consider trying this on real hardware eventually.
I am testing all the kogics the only way I know, by trying.
I have done a lot of bench testing and debugging, and today first time in car..
Still have a lot of testing left to make sure I have all the logic correct first of all..
The code needs cleaning and someone to refine it eventually, if there are any real demand/interest for this.
Has anyone used it? Do we have any logs or videos?
There was a video posted a while back with a Subaru using it. If no one has done anything yet ill be putting a large bounty on getting it running smoothly as I 100% want/need this for my own build and for the pnp kits ill be making for audm only vehicles
We have confused at least Elmepro with the "range" terminology: we use "launch RPM + range" for example 2000 launch and 200 range for total hard cut at 2200 while Elmepro was expecting RPM 1700 and range 1700 to run at 1700, not 3400 as we do.
