Configuration assistance
It's all about the code!
dj_nexxus
Post by dj_nexxus »
Good day guys, I have been playing with speeduino and rusefi for some time and have created a board specific for my RB25DET based on the speeduino system, I am in the process of learning the workings of both speeduino and rusefi source code but have a long way to go including datasheets, but just to get something running in the interim I am trying to get the engine to atleast idle. my problem being I am using an STM32F407 as my cpu which is still experimental in speeduino I want to try rusefi on my board but I noticed in the TS software PE0 and PE1 are not selectable. question now being , can I just add those two pins to the rusefi.ini file to enable them?
Re: Configuration assistance
Please be more specific. We have zero experience with speeduino and it would be nice to know which dialog/what function are you talking about here.
I can use my limited telepathic ability and suggest trying https://rusefi.com/build_server/rusefi_bundle_frankenso_na6.zip but please do better in terms of important details.
We rely on https://rusefi.com/online as a tool for questions like that. Please consider sharing your tune to help us help you.
dj_nexxus
Post by dj_nexxus »
My apologies brain is tired.....PE0 and PE1 are used in the speeduino conig I am using to read both the primary and secondary crank signal respectively, the sensor being read is a Nissan 360CAS producing a 1degree primary signal and 6 60 degree pulses for the cylinder refrences.....I am using the Proteus hardware to guide me on the rusefi side.....with regards to tune, none so far.....just working on the hardware right now......apologies again for the missing info..
We don't support the 360 tooth wheel - I'd recommend one of the inexpensive 24 tooth wheels that fits in your CAS, those are well supported.
