Enable Flood clear: True or false.
On an ETB setup, is this based on the TPS or PPS input?
If TPS based, this could be problematic if the "Maximum ETB position (%)" or "ETB Pedal Target" relationship is defined/mapped such that the TPS would never reach >95% opening while in the cranking RPM zone.
Regardless of TPS or PPS based logic; would it make sense to instead have a setting that would let the user define which TPS threshold would activate flood clear, eg. fuel cut-off while RPM < "Cranking RPM limit" instead of having the fixed 95% threshold?
Cranking Settings -> Advanced -> Flood clear
tmbryhn
Re: Cranking Settings -> Advanced -> Flood clear
It checks against our synthetic "driver throttle intent" channel. In case of cable throttle it uses TPS, in case of electronic throttle it uses the pedal.
tmbryhn
To be clear; is the threshold still 95% pedal input in ETB mode for activating flood clear?
Affirmative.
