Hello,
I found out that the part of my wiring harness regarding negative injector cables are batches of three injectors each, grounded to two DME connector pins ! I've heard that Proteus may fail grounding batches of more than two injectors at high load or rpm
so I'd rather connect injectors ground individually on proteus !
The 55 pins connectors can't be used because of it's 4 injectors outputs and same issue with my 88 pins spare wiring harness ! Only the 134 pins seems to have individual injector pinout, a great feature
What do you think about batched injection ?
One of my injector batch not only grounds do one of the DME but goes into the EML, so not sure about cutting into injector ground wiring to break the bundles ! I'll test which pins of the EML are wired to the bundles of injectors and send you what I found with pictures ! I discussed with a rusEFI member (thanks Bill) and his vee12 runs on proteus without EML so as I'm getting rid of my zf4hp24 auto trans and fitting a gs6 35dz hgk, I maybe don't need EML as TCM will become useless !
What do you think of EML, is it important to keep it for cluster and other BMW stuff or is it ok to run engine without it ?
Have a great day and thank you so much for your willing to help
