I have a similar issue, when i rev engine smoothly, it stucks at 4k-ish RPMs, like it does launch control with 30rpm swing. RPM gauge peaks or drops randomly etc.
On the other hand when I rev the engine hard (or when RPM passes 4k-ish RPMs, it can goes to RPM limit without any error.
1.tried calculate pull up/down resistor values according to CPS sensor datasheet
2.tried with 4 MRE ECUs with same build, and ECUs with different filtering settings (adding filtering caps and/or resistor or without any pull-up/down resistors or any capacitors (PS: it is going bad without any resistors. don't try))
3.tried different CPS sensor bracket (for case of mechanical problem)
4.tried different CPS sensor distances (from 0.3mm to 1mm)
5.tried different CPS sensors (1 new and 1 used-from a working car)
6.tried changing signal pin to CAM hall input.
7.tried machining the wheel for balance and uneven surfaces
8.tried different firmwares
9.tried to get log but i couldn't make it. obviously im not good at using softwares
Tomorrow I will check raw sensor data with oscilloscope and make a new CPS bracket from aluminium. Maybe iron bracket is magnetizing the sensor?, i want to be sure.
-it is a 4A-F (carburateur) to 4A-FE conversion project and i could not find the original trigger wheel so i used BMW 60-2. Will post tune and logs when i could.
Another Weird RPM issue
stwillocks
- Github Username: stwillocks
- Slack: Suleyman TURAN
-STRD
One man's "magic" is another man's engineering, "supernatural" is null word.
-Robert Heinlein
Daily driven Golf MK3 ABF 16V Turbo
making about 700ps
-Robert Heinlein
making about 700ps
Re: Another Weird RPM issue
A lot of text but the most important piece is missing.
Please consider looking at my forum signature.
stwillocks
Excuse me, it was meant to be reply a thread,
I will update post ASAP. Thank you for warning Andrey
-STRD
-Robert Heinlein
making about 700ps
-Robert Heinlein
making about 700ps
Please do not mix potentially unrelated issues.
stwillocks
It is awkward to write this that late but I fixed the problem. Turns out trigger sensors are VR.
Guy who get me the sensors told me the sensors are HALL EFFECT. So I did the harness and ECU config for HALL.
Lesson learned :
Don't rely on hearsay
Check everything at least twice.
How to upload tune and Log To rusefi Online.
BTW: Log, tune, scope video below
Will upload scope screens later
https://rusefi.com/online/?vehicleName=TorbaciMobil&user_id=1412&sorts[uploadedMsq]=-1&sorts[uploadedLog]=-1
I'm open to your criticisms.
Lesson learned :
-STRD
-Robert Heinlein
making about 700ps
-Robert Heinlein
making about 700ps
Well, LOL
it not just _runs_ it _drives_ which put you in the 10% of rusEFI projects right here.
please mention "rusEFI" or better "#rusEFI" in the video title if possible?
stwillocks
Done. For your information the videos are unlisted
-STRD
-Robert Heinlein
making about 700ps
-Robert Heinlein
making about 700ps
