TS KIA TPS calibration
Hi, I'm having an issue with the TPS on a 91 Miata, I've recently purchased a 91 PNP hellen rev B unit. I have swapped out the TPS for a Kia unit,I have moved the pins around on the TPS connector and managed to calibrate the TPS thru TS tools. The values I get are ball park, foot off 260, foot on, 980. however on restart TS is coming up with an error, despite the TS throttle gauge showing 0-100% when I depress the throttle. Check configuration "Tps1Primary" problem :open 0.00/closed0.00 cal values are too close together. Check your calibration an wiring. What am I doing wrong?
1991 1.6 Mazda Eunos Roadster, 5sp, Normally Aspirated
Re: TS KIA TPS calibration
Sounds like calibration is not being saved.
Are you hitting 'burn'? Do you calibrate while engine is running? Do you see "unsaved changes" indicator in TS?
Try saving some other setting maybe vehicle name. Does that get saved?
Please attach screenshots and log link from reo. To note, you do not rewire for kia tps. It is pnp for us.
I'll repin back to original, I wasn't getting a reading before. will try starting again with fresh project. Thanks
re-pined to original, values are now backwards, but all errors are cleared. car starts, smell rich and rough, Hi idle (1400) and dies after a few seconds. So i guess I'm on the right track. thanks
