NA Miata EcotecMiata Race Car
This is our shop race car. It is an NA Miata with some mods to go a bit faster than SpecMiata.
GM LSJ Engine (Saab B207R)
T56 F-body Trans with Quicktime Bellhousing
7163 EFR Turbo
Is pictured as GT4 class, but we broke out and it has been bumped to GT3. For a speed reference, this is 1:31 on 275 AR1's at Mosport. Car is easily capable of going faster but that is the breakout for GT3. Once you move to GT2 you are playing with the big boys in tube chassis cars. Best guess is maybe a 1:29 on AR1 and a couple more seconds on Hoosiers
This car was on MS3, with a separate DBWX2 box for the throttle. This winter we swapped it to MRE (due to the success I had with the MRE on previous projects, and a mid race failure of the MS3PRO ecu). The car has two PDMs, PodiumConnect, AEM VDM, RaceCapture dash, Blink button panel, MK60 ABS, Toyota EPS, so lots of Can devices. Last year we had a teensy based controller to manage the Can messages to control the PDMs, buttons, etc. With Lua being added to MRE I thought this would be a great way to get rid of a device and integrate the control into the ECU.
7163 EFR Turbo
Matt
MT Motorsport / EcotecMiata
Re: NA Miata EcotecMiata Race Car
Thank you for posting this, feels great to see MRE being useful
Please let me know once/if https://github.com/rusefi/rusefi/issues/3970 becomes a blocker for you.
Further to the Lua Scripting thread, here is the complete code as it sits on the car right now. Everything is working as intended with one exception. I would like to grab the brake pedal pressed message from the can bus. If it could be set as the brake input for DBW safety that would be great otherwise if I could just relay the brake state to a cantx message that would work as well.
ID = 351211806 is the message that contains the brake state. If byte 1 is 128 and byte 4 is 16 the pedal is depressed. If byte 4 is 0 the pedal is release. This message is continuously broadcast, requires no handshake or tx request.
I would like to pass the state of the brake switch to Rusefi for DBW and also to the txCan message with ID 351215889. This txCan message is already being broadcast and the other functions contained in the payload are working as expected.
d = 0
df = 0
w = 0
wp = 0
t = 0
tl = 0
h = 0
hz = 0
br = 0
local cm = 0
canRxAdd(418381601)
canRxAdd(351211806)
setTickRate(1)
function onCanRx(bus, id, dlc, data)
if id == 418381601 then
bn = data [4]
bs = data [5]
if bn == 3 and bs == 1 then
t = (t + 1)
if (t % 2 == 0) then
tl = 0
else
tl = 127
end
end
if bn == 2 and bs == 1 then
w = (w + 1)
if (w % 2 == 0) then
wp = 0
else
wp = 127
end
end
if bn == 1 and bs == 1 then
d = (d + 1)
if (d % 2 == 0) then
df = 0
else
df = 127
end
end
if bn == 5 and bs == 1 then
h = (h + 1)
if (h % 2 == 0) then
hz = 0
else
hz = 127
end
end
if id == 351211806 then
bks = data [1]
bk = data [4]
if bks == 128 and bk == 16 then
br = 0
else
br = 127
end
end
end
end
function pdmSetup()
txCan(1, 351215121, 1, { 0, 1, 255, 0, 255, 255, 0, 255 })
txCan(1, 351215121, 1, { 0, 2, 255, 0, 254, 255, 4, 255 })
txCan(1, 351215121, 1, { 0, 3, 255, 0, 255, 255, 6, 45 })
txCan(1, 351215121, 1, { 0, 4, 255, 0, 254, 255, 0, 255 })
txCan(1, 351215121, 1, { 0, 5, 75, 1, 252, 255, 5, 255 })
txCan(1, 351215121, 1, { 0, 6, 75, 1, 252, 255, 5, 255 })
txCan(1, 351215121, 1, { 0, 7, 255, 1, 252, 255, 4, 255 })
txCan(1, 351215121, 1, { 0, 8, 255, 0, 254, 255, 0, 255 })
txCan(1, 351215121, 1, { 0, 9, 255, 0, 254, 255, 0, 255 })
txCan(1, 351215121, 1, { 0, 10, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215121, 1, { 0, 11, 255, 0, 255, 255, 6, 173 })
txCan(1, 351215121, 1, { 0, 12, 255, 0, 252, 255, 4, 255 })
txCan(1, 351215121, 1, { 6, 110, 110, 110, 46, 109, 109, 255 })
txCan(1, 351215121, 1, { 7, 110, 110, 110, 28, 44, 110, 255 })
txCan(1, 351215889, 1, { 0, 1, 255, 0, 252, 255, 4, 255 })
txCan(1, 351215889, 1, { 0, 2, 255, 0, 255, 255, 4, 255 })
txCan(1, 351215889, 1, { 0, 3, 255, 0, 255, 255, 4, 255 })
txCan(1, 351215889, 1, { 0, 4, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 5, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 6, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 7, 255, 0, 252, 255, 4, 255 })
txCan(1, 351215889, 1, { 0, 8, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 9, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 10, 255, 0, 255, 255, 6, 255 })
txCan(1, 351215889, 1, { 0, 11, 255, 1, 252, 255, 4, 255 })
txCan(1, 351215889, 1, { 0, 12, 255, 1, 252, 255, 4, 255 })
txCan(1, 351215889, 1, { 6, 110, 110, 110, 44, 44, 44, 255 })
txCan(1, 351215889, 1, { 7, 46, 44, 44, 44, 110, 110, 255 })
end
function radFan()
local fan = getOutput("isFanOn")
if fan == 1 then
rf = 127
else
rf = 0
end
end
function fuelPump()
local fuel = getOutput("isFuelPumpOn")
if fuel == 1 then
fs = 127
else
fs = 0
end
end
function onTick()
if cm == 0 then
pdmSetup()
cm = 1
end
fuelPump()
radFan()
txCan(1, 351215121, 1, { 4, rf, 127, 0, 127, wp, 0, 63 })
txCan(1, 351215121, 1, { 5, df, 127, 127, 0, 0, 127, 63 })
txCan(1, 351215889, 1, { 4, tl, br, hz, 0, 0, 0, 63 })
txCan(1, 351215889, 1, { 5, fs, 0, 0, 0, fs, fs, 63 })
end
Matt
Does this mean available Lua space can change dynamically, while the engine is running? Eg: if my script fits in available space with engine off, it might overflow once engine is running?AndreyB wrote: ↑Sat Mar 26, 2022 3:53 pmThank you for posting this, feels great to see MRE being useful
Matt
No-no-no
This is about us not using 427/429 fully
Makes sense.
I wonder if someone could help with this section of script. It seems to pull the 351211806 data correctly, but does not pull the 418384601 data. This also causes a Lua out of memory condition when a 418384601 message is received. The following error is printed in the Console.
2022-03-27_12_12_59_026: EngineState: LUA CAN RX error not enough memory
If I comment out the 351211806 section then the 418384601 part works as intended with no other changes to the script.
canRxAdd(418381601)
canRxAdd(351211806)
id1 = id
if id1 == 418381601 then
bn = data [4]
bs = data [5]
t = (t + 1)
tl = 0
else
tl = 127
end
end
w = (w + 1)
wp = 0
else
wp = 127
end
end
d = (d + 1)
df = 0
else
df = 127
end
end
h = (h + 1)
hz = 0
else
hz = 127
end
end
end
if id1 == 351211806 then
bks = data [1]
bk = data [4]
br = 127
else
if bks == 128 and bk == 0 then
br = 0
end
end
end
end
Matt
I've made the change I was talking about - please take latest firmware https://rusefi.com/build_server/rusefi_bundle_mre_f4.zip in about 15 minutes from now, this would double Lua RAM if your unit has proper microcontroller.
luamemory rusEFI console command is your friend, that would show how of available RAM you've used.
But as he's discovered, it can fluctuate up and down as the script runs. It's best to have significant headroom available to "weather the perfect storm" of memory usage.
I think there is something wrong with how I'm calling the canRx. If I just call one can ID it uses 65% of available space. Adding the last if statement in the function oncanRx causes 2000% memory usage.
Matt
please confirm that you've updated the firmware
please provide exact luamemory outputs for different scenarios to give us a bit more visibility
ideally please provide two full versions which behave too differently, "if I change xxx" is too vague to reproduce for me.
Just loaded this new firmware build.
Everything works as intended in the script below with the following luamemory result
2022-03-27_22_18_50_615: EngineState: Lua memory heap 0: 16828 / 60000 bytes = 28.0%
2022-03-27_22_18_50_615: EngineState: Lua memory heap 1: 0 / 12000 bytes = 0.0%
This luamemory situation is odd because this is the lowest memory utilization I have ever seen. I'm not complaining, obviously, just weird that even prior to this stage when I had fewer functions it was still consuming more memory. This gives me hope that I can code in the PDM current feedback to illuminate the button panel backlights as driver feedback that outputs have been enabled.
Thank you guys so much, this is so cool.
d = 0
df = 0
w = 0
wp = 0
t = 0
tl = 0
h = 0
hz = 0
br = 0
local cm = 0
canRxAdd(418381601)
canRxAdd(351211806)
setTickRate(20)
bn = data [4]
bs = data [5]
t = (t + 1)
tl = 0
else
tl = 127
end
end
w = (w + 1)
wp = 0
else
wp = 127
end
end
d = (d + 1)
df = 0
else
df = 127
end
end
h = (h + 1)
hz = 0
else
hz = 127
end
end
end
bks = data [1]
bk = data [4]
br = 127
else
br = 0
end
end
end
end
function pdmSetup()
end
function radFan()
if fan == 1 then
rf = 127
else
rf = 0
end
end
function fuelPump()
if fuel == 1 then
fs = 127
else
fs = 0
end
end
function onTick()
if cm == 0 then
pdmSetup()
cm = 1
end
fuelPump()
radFan()
txCan(1, 351215121, 1, { 4, rf, 127, 0, 127, wp, 0, 255 })
txCan(1, 351215889, 1, { 4, br, tl, hz, 0, 0, 0, 63 })
end
Matt
Lowest percent or lowest bytes? We just made the available memory bigger so your percent used went down for the same byte usage
Also, some amount of that memory is used by the Lua virtual machine itself - a blank script will still have non-zero memory usage.
Lowest percent for sure due to the 60k being available vs 25k before. I don't have time right now to load the previous firmware and reload the lua script but I seem to recall it being higher bytes than this iteration as well, into the 20k region.
Matt
Looks rad. Do you think the ecotec swaps would be a good candidate for a pnp ecu?
i.e. we have a solution (rusEFI) we are looking for a marketBeerMoneyMotorsports wrote: ↑Wed Mar 30, 2022 8:09 pmLooks rad. Do you think the ecotec swaps would be a good candidate for a pnp ecu?
E67 plug and play?
Would have to be waterproof, as ecu lives underhood.
stock ecu is $25 from junkyard and operating system supports 5 bar map sensor, so you would have to have a really compelling case to use it. We use standalone because closed loop wideband and built in boost control. OE ecu will not do either of those.
Real good idea is E39 plug and play. Direct injected ecotec variants have very poor HP Tuners support and can never be tuned to run properly in a standalone configuration. Current aftermarket DI ECUs are $1200+ and require at least modifying the stock harness. E39 also applies to HF V6 engine family which is a common miata swap as well.
Matt
Thank you, noted!
E67 is currently in the works
https://rusefi.com/forum/viewtopic.php?p=44864#p44864
E39 noted, GDI is currently in the works. Any chance you would be interested to some early testing of GDI prototypes?
nice setup! any pictures of the engine/ drivetrain??
I'm working on E39 on a Tahoe.
"Dave B. 5:03 PM
I can help with testing if needed. I have a DI Ecotec with additional port injectors (8 injectors total) currently running on Motec that I could easily make a patch harness to rusefi.AndreyB wrote: ↑Fri Apr 01, 2022 1:46 amThank you, noted!
I suppose I should get my hands on a Proteus for testing?
Matt
Yes please.mtmotorsport wrote: ↑Wed Apr 06, 2022 3:53 amI suppose I should get my hands on a Proteus for testing?
As of today please start wiring Proteus to BMW 7506280 on the right. Hopefully in a few weeks we will have firmware for rusEFI GDI4 (on the left) which is pin compatible.
- rusefi-gdi4-compatible-with-7506280.jpg (485.81 KiB) Viewed 29344 times
Just had the car on the dyno with good results.
Stock LSJ engine
B207 intake manifold
LNF exhaust manifold
Stock location EFR 7163
Bosch 1000cc injectors
17psi flat to redline. Will add some reverse taper to help torque up top but it really doesn't need it.
Rev limiter set to 7200, with soft at 7000rpm. Link to short vid
Stock LSJ engine
Matt
Can you please upload your tune to http://rusefi.com/online unless it's really confidential?
Wow thank you for the sweet rusEFI bragging material!
Done. Nothing confidential, haha. The tune isn't really polished yet, just calibrated the cell we could reach on the dyno.
Matt
I see "sequential" on https://rusefi.com/online/view.php?msq=946&dialog=injectorConfig and CAM input is selected by greyed out on https://rusefi.com/online/view.php?msq=946&dialog=triggerConfiguration
It's greyed out since cam wheel shape is not selected on https://rusefi.com/online/view.php?msq=946&dialog=triggerConfiguration_IO
That's actually OK, I run in the same mode. Unless you really care about emissions, that 50/50 chance of when your injection timing happens doesn't really matter. Sequential gets you one firing per cycle instead of two, so any errors from deadtime etc are reduced by half.AndreyB wrote: ↑Mon Apr 11, 2022 5:55 pmI see "sequential" on https://rusefi.com/online/view.php?msq=946&dialog=injectorConfig and CAM input is selected by greyed out on https://rusefi.com/online/view.php?msq=946&dialog=triggerConfiguration
This is actually due to a bad cam signal noise issue we are having. I had to disable it and turn ignition to wasted COP. Normally these engines have a Bosch quick start (4 tooth) cam sensor module in the rear of the cylinder head. We removed that because we pushed the engine back about 4" from its normal position. In place of that sensor I installed a hall sensor in the valve cover, attempting to get a single cam pulse off one cam lobe. This works flawlessly as long as the ignition coils do not fire. As soon as ignition is enabled you can "see" each coil fire on the composite tooth logger. I suspect some shielded cable, or better noise suppression will fix it, but right now it runs fine.
Matt
what kind of gas did you use? street premium or something fancier?
91 octane, pump gas. Nothing special. Car will run 1-3 hours endurance races and 25 minute sprint races. Fancy fuel is too expensive. Might get a hold on some E85 and try that. This was the original reason for the 1000cc injectors.
Matt
- Github Username: duhafnusa4
- Slack: Jimmy *un*el
any updates?
