Hi , I have a custom board base on Proteus running latest firmware ("rusEFI 2022.03.16.proteus_f4.1421086421"), I have a AIM MXL Pista dash and test Haltech dash and don't work, I also check with VAG and AIM and this work fine (can communication it's fine in board).
I check in Console and Haltech don't send any messages, I want the Haltech protocol because have more information, It's posible to check this error.
Thanks.
https://github.com/mck1117/proteus/issues/111
Haltech CAN bus Communication don't work.
hugovw1976
- Github Username: hugovw1976
hugovw1976
Re: Haltech CAN bus Communication don't work.
I check code apparently Haltech dash is not initiate:
void canDashboardBMW(CanCycle cycle);
void canDashboardFiat(CanCycle cycle);
void canMazdaRX8(CanCycle cycle);
void canDashboardW202(CanCycle cycle);
void canDashboardBMWE90(CanCycle cycle);
void canDashboardVagMqb(CanCycle cycle);
void canDashboardNissanVQ(CanCycle cycle);
void canDashboardGenesisCoupe(CanCycle cycle);
void canDashboardAim(CanCycle cycle);
void updateDash(CanCycle cycle) {
// Transmit dash data, if enabled
switch (engineConfiguration->canNbcType) {
case CAN_BUS_NBC_BMW:
canDashboardBMW(cycle);
break;
case CAN_BUS_NBC_FIAT:
canDashboardFiat(cycle);
break;
case CAN_BUS_NBC_VAG:
canDashboardVAG(cycle);
break;
case CAN_BUS_MAZDA_RX8:
canMazdaRX8(cycle);
break;
case CAN_BUS_W202_C180:
canDashboardW202(cycle);
break;
case CAN_BUS_BMW_E90:
canDashboardBMWE90(cycle);
break;
case CAN_BUS_MQB:
canDashboardVagMqb(cycle);
break;
case CAN_BUS_NISSAN_VQ:
canDashboardNissanVQ(cycle);
break;
case CAN_BUS_GENESIS_COUPE:
canDashboardGenesisCoupe(cycle);
break;
case CAN_AIM_DASH:
canDashboardAim(cycle);
default:
break;
}- AndreyB
Nice just made this better https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
but that also shows that this code is totally untested and unproven
hugovw1976
ThanksAndreyB wrote:Nice just made this better https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
Enviado desde mi SM-G988U1 mediante Tapatalk
hugovw1976
I compile firmware with the new lines on can_dash.cpp, and can confirm Haltech can communication works now, just need to check if all the channel are correct but I don't have time until the weekend.AndreyB wrote: ↑Wed Mar 23, 2022 2:54 pmNice just made this better https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
but that also shows that this code is totally untested and unproven![]()
Thanks.
hugovw1976
Check all output channels and looks good, just the Intake temperature and fuel level is not declared in can_dash.cpp
Air temperature is the intake air temperature. must be :
Fuel Level in code:
must be:
Intake Air Temperature tested and working, Fuel Level not nested.
/* 0x3E0 = 5Hz rate */
CanTxMessage msg(0x3E0, 8);
/* Coolant temperature in K y = x/10 */
tmp = ((Sensor::getOrZero(SensorType::Clt) + 273.15) * 10);
msg[0] = (tmp >> 8);
msg[1] = (tmp & 0x00ff);
/* Air Temperature */
msg[2] = 0x00;
msg[3] = 0x00;
/* Fuel Temperature */
msg[4] = 0x00;
msg[5] = 0x00;
/* Oil Temperature */
msg[6] = 0x00;
msg[7] = 0x00;
}Code: Select all
tmp = ((Sensor::getOrZero(SensorType::Iat) + 273.15) * 10);
msg[2] = (tmp >> 8);
msg[3] = (tmp & 0x00ff);
msg[4] = 0x00;
msg[5] = 0x00;
msg[6] = 0x00;
msg[7] = 0x00;
}Code: Select all
/* 0x3E2 = 5Hz rate */
CanTxMessage msg(0x3E2, 2);
/* Fuel Level in Liters */
msg[0] = 0x00;
msg[1] = 0x00;
}Code: Select all
tmp = (Sensor::getOrZero(SensorType::FuelLevel)* 10);
}- AndreyB
Please-please-please invest an hour of your time to properly fork https://github.com/rusefi/rusefi and push changed into your fork?
Reminder that worst case scenario you can edit files via the browser or upload files into your fork of https://github.com/rusefi/rusefi
You fix is valuable but please make it move valuable by going the proper GH route to reduce my efforts to accept your fix.
hugovw1976
Sorry I'm very new on this, is any guide to made fork.AndreyB wrote:Please-please-please invest an hour of your time to properly fork https://github.com/rusefi/rusefi and push changed into your fork?
Please go over https://docs.github.com/en/get-started/quickstart/fork-a-repo
We are talking about one click in the right-top corner of https://github.com/rusefi/rusefi once you have a github account.
Also forum is not a chatting platform.
Slack is the chatting platform we should be using for chatting see https://rusefi.com/forum/viewtopic.php?f=13&t=1198
