86 - 88 should be more similar than newer year. 89 the cars went from SpeedDensity to MAF. 93 Cobra's had a odd pinout for the injectors I think it was injector 7 that they moved to a different pin location. Weather permitting I got the adapter cables soldered up today tomorrow I will plug it into my car and see what I see.
I fired it up today with some mixed results. I seem to be reading the MAP sensor, Volts, dwell and timing but can not seem to read the TPS, IAT, CLT and some other things. I check the the wiring pinout and it matches what you have here. I suspect it's in my SW configuration. For instance it's asking me about 2 Throttle bodies and I only have 1. So I suspect I have a wrong config mapping or something going on to sort out.
Here's my Tuner Studio Files. If anyone has any ideas on the following it would be very helpful.
1. Fuel Pump Seems to be turned off in Tune when I check status but do not see how to turn it back on.
2. CLT/IAT getting readings but they are incorrect.
3. TPS not registering anything at all. Has Dual TB configuration. Not sure how to set for single throttle body.
Thanks for any help.
So when you turn the key on the ECU does not prime the fuel system like the factory ECU you have to crank it?
On the TPS I tried both 2 and 3 settings neither seems to work. I'll check with a meter but it works fine with my stock ecu should not be a wiring issue.
the CLT and IAT settings I don't know off the top of my head been searching online for answers.
Are the Ford to Proteus adapters still available at all? Is anyone still working on this project? The Github hasn't been updated in a few years. Any chance of this ever leaving beta or perhaps becoming a Hellen? I have a Foxbody that I want to engine swap and am considering my options for a DIY standalone ECU.
