DFU from Linux
It's all about the code!
ayard
DFU from Linux
Post by ayard »
Hi all,
I've been flashing the Proteus boards from my Linux machine using STLINK v3. But on the 0.6 board, there is no easily accessible JTAG connector other than the Tag-Connect connector. Since I don't have a Tag-Connect adapter, I thought I would use DFU over USB instead. I think I have the correct tools in place to do this from my Linux machine, but it requires a .dfu file. How do I convert from an .elf file to a .dfu file format?
Thanks,
Al
Re: DFU from Linux
All our firmware bundle zips include both bin and dfu - do you really need your own build?
Re: DFU from Linux
Also, the other side of the board has a footprint for the standard 10 pin cortex debug connector.
Re: DFU from Linux
And if you need your own .dfu please see how our scripts produce those.
ayard
Re: DFU from Linux
Post by ayard »
Mon Oct 04, 2021 7:59 pm
O/K .... thanks .... I'll look at the scripts and see if I can work it out from there.
Some of my planned projects will use the rusEFI firmware, which has the *.dfu file, some of the other projects aren't suitable for the rusEFI firmware, so I've written my own firmware for these, and need to convert the *.elf to a *.dfu.
Al
Dron_Gus
Github Username: dron0gus
Re: DFU from Linux
Post by Dron_Gus »
cd firmware/ ; cat flash_dfu.sh
#!/bin/bash
# This is a Linux/Unix script to do USB DFU (Device Firmware Update).
# The STM32 has multiple ways to write an application into the MCU.  One is
# is USB DFU mode.
# This can write a blank or overwrite a corrupted ECU, but does require
# that the processor be set into DFU mode by holding down the 'Program' (AKA
# 'Boot1') button at reset or power up.
# Note: The 'Program' button is only checked immediately after reset.  The
# button may be released after that instant.  A reset or power cycle may be
# needed to exit DFU mode.
# Future: Consider if creating a build/rusefi.dfu install file is more
# or less descriptive than multiple command line parameters.
dfu-util --alt 0 --download build/rusefi.bin --dfuse-address 0x08000000 --reset
# For Windows the batch file flash_dfu.bat runs the equivalent command
#   DfuSeCommand.exe -c -d --fn build/rusefi.dfu
Re: DFU from Linux
probably, this line can be invoked from rusefi console?
however, it requires that dfu-util is installed.
ayard
Re: DFU from Linux
Post by ayard »
I'm slowly gaining on this!
I found a little utility "elf2dfu", I just had to modify it for the correct PID/VID. This does the conversion from *.elf to *.dfu. Then I use dfu-util to do the upload.
On the Proteus 0.6 board, everything works great.
On the 0.4 board, it errors out. Apparently, this is a problem with the STM ROM code, they have a string descriptor where the length of the string doesn't match the length field. There are work-arounds for this, but I haven't bothered yet if it's only going to be this 1 board.
On the 0.3 board, it doesn't work at all. When you put the board into boot mode, the USB port doesn't even enumerate. I know the USB port is good, I use it for communication when the firmware is running.
Al
