What does startup pin state error mean
Kavabanga
Post by Kavabanga »
Hello, guys!
Please, tell me, what it means?
What's wrong?
Here is the tune:
https://rusefi.com/online/view.php?msq=496
I have this error with versions of the software released after mach, 10, 2021
Re: What does XXX error mean
firmware validates expected state of hardware in terms of electric pull down or pull up
looks like on your board there is no pull in the expected direction so firmware refuses to operate in an unsafe setup
i should make error message a bit more clear
Kavabanga
Post by Kavabanga »
Ok, thank you!
But why don't I have this message with previous versions of the software?
For example, posted in December, 18, 2021?
And how to fix this error?
dbh97
Github Username: chuckwagoncomputing
Slack: dbh97
Re: What does startup pin state error mean
Post by dbh97 »
I'm not sure why it shows this error if ETB is disabled, and I don't think it is supposed to, but I think you can fix it by going to "Full Pinout 1/3" in the "Controller" menu and set the ETB pins to "NONE".
