[MRE] Firmware mismatch with Tuner Studio
2024 edit: this post is a bit outdated, we now use stm32cubeprogrammer instead of DfuSeCommand.exe overall see https://github.com/rusefi/rusefi/wiki/rusEFI-Quick-Start-PDF
Hi all,
After almost a year of sitting around, I finally got round to connecting my microRusEfi to the computer...
only to be met with Tuner studio not accepting the connection with it.
I've tried with both .ini files / projects (for v0.3 and below / STM32F7 and v0.4 and above / STM32F4) but in both cases, it gives me the attached error.
Is there something I'm doing wrong?
Thanks for the help,
Hi all,
Re: [MRE] Firmware mismatch with Tuner Studio
update the firmware on your ECU, looks like it's running pretty old firmware.
Yes, you are trying to use a unit with old firmware with a new project definition file. Your project definition file should match your firmware. If you want to connect to that old firmware as is, you need to find a matching project definition file.
You are much better updating to latest release and using matching fresh firmware and project definition .ini file
https://github.com/rusefi/rusefi/releases
Thanks for the reply.
I've looked a bit into it and from what I've gathered, I should download the rusefi console and update directly in DFU mode. Correct me if I'm wrong
One thing I can't figure out though is which package to select : in the latest Malbec release I can't seem to choose...
I would say the autoupdate.zip but not exactly sure... there's also the generic rusefi_bundle.
What are the differences between all these?
rusefi_bundle_mre_f4_autoupdate.zip
rusefi_bundle_mre_f4_hardware_QC_special_build.zip
rusefi_bundle_mre_f4_hardware_QC_special_build_autoupdate.zip
rusefi_bundle_mre_f4_recovery.zip
rusefi_bundle_mre_f4_recovery_autoupdate.zip
https://github.com/rusefi/rusefi/wiki/microRusEFI-Manual has the best link and a lot of other useful info for microRusEFI users
Thanks Andrey!
I guess I'm a bit thick but I can't seem to get the console to open...
I'm trying to execute rusefi_console.exe that's in the latest bundle (20210417_121019_mre_f4_rusefi) but nothing happens...
rusefi_autoupdate.exe does launch a java window prompting me to choose between 4 options for the update. I pressed once and it went to another blank page...
Just looked at the video on how to program 1st time / 2nd time the MRE : it's running Win 7 like me so I guess the problem comes from my configuration. Is there a specific java version to be installed or maybe an update?
can you please open "cmd" window and launch java_console.exe from that terminal window? I assume there is an error which you just do not see.
Seeing four buttons tells me that you have at least some relevant java.
java console is working best under java 8, open question if having newer java could be an issue. I would love to see what error you see in that "cmd" window.
Well...
java_console.exe in the terminal doesn't execute anything.
I've searched for this particular file but no trace of it.
I did go into the java control panel and checked "show console" but it made no difference. I also updated it to version 8 Update 291.
Oh and if I execute java under the terminal, it gets me this :
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Marc>java_console.exe
'java_console.exe' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Marc>cd..
C:\Users>cd..
C:\>java
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-client to select the "client" VM
-server to select the "server" VM
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A ; separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose:[class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
Warning: this feature is deprecated and will be removed
in a future release.
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -no-jre-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See http://www.oracle.com/technetwork/java/javase/documentation/index.html for m
ore details.
C:\>java -console
Unrecognized option: -console
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Please try
from the folder which contains that file not from c:\ root folder
java -jar rusefi_console.jar
Same java_console.exe please try it from the folder which contains it since "'java_console.exe' is not recognized as an internal or external command"
And here they are : first the java- jar rusefi_console.jar and then java_console.exe
C:\Users\Marc>cd documents
C:\Users\Marc\Documents>cd rusefi
C:\Users\Marc\Documents\RUSEFI>cd snapshot_20210416_121019_mre_f4_rusefi
C:\Users\Marc\Documents\RUSEFI\snapshot_20210416_121019_mre_f4_rusefi>cd console
C:\Users\Marc\Documents\RUSEFI\snapshot_20210416_121019_mre_f4_rusefi\console>ja
I 210423 211518.972 [main] Launcher - rusEFI UI console 20210415
I 210423 211519.019 [main] Launcher - Compiled Fri Apr 23 00:19:07 CEST 2021
Tool available: compile_fsio_file
Convert all lines from a file to RPN form.
Tool available: compile_fsio_line
Convert a line to RPN form.
Tool available: convert_binary_configuration_to_xml
NOT A USER TOOL. Development tool to convert binary configuration into X
ML form.
Tool available: decompile_fsio_line
Convert a line from RPN form.
Tool available: detect
Find attached rusEFI
Tool available: dfu
Program specified file into ECU via DFU
Tool available: firing_order
NOT A USER TOOL. Development tool relating to adding new firing order in
to rusEFI firmware.
Tool available: functional_test
NOT A USER TOOL. Development tool related to functional testing
Tool available: get_image_tune_crc
Calculate tune CRC for given binary tune
Tool available: get_performance_trace
DEV TOOL: Get performance trace from ECU
Tool available: get_xml_tune_crc
Calculate tune CRC for given XML tune
Tool available: headless
Connect to rusEFI controller and start saving logs.
Tool available: help
Print this help.
Tool available: lightui
Start lightweight GUI for tiny screens
Tool available: local_proxy
Detect rusEFI ECU and proxy serial <> TCP
Tool available: network_authenticator
rusEFI Online Authenticator
Tool available: network_connector
Connect your rusEFI ECU to rusEFI Online
Tool available: print_auth_token
Print current rusEFI Online authentication token.
Tool available: print_vehicle_token
Prints vehicle access token.
Tool available: ptrace_enums
NOT A USER TOOL. Development tool to process performance trace enums
Tool available: read_tune
Read tune from controller
Tool available: reboot_dfu
Sends a command to switch rusEFI controller into DFU mode.
Tool available: reboot_ecu
Sends a command to reboot rusEFI controller.
Tool available: set_auth_token
Set rusEFI Online authentication token.
Tool available: upload_tune
Upload specified tune file to rusEFI Online using auth token from settin
gs
Tool available: version
Only print version
Tool available: write_tune
Write specified XML tune into controller
rlog Writing to logs/MAIN_rfi_report_2021-04-23_21_15_19_139.csv
Exception in thread "main" java.lang.IllegalStateException: java.io.FileNotFound
Exception: logs\MAIN_rfi_report_2021-04-23_21_15_19_139.csv (Access is denied)
at com.rusefi.FileLog.start(FileLog.java:57)
at com.rusefi.ConsoleUI.startUi(ConsoleUI.java:180)
at com.rusefi.Launcher.main(Launcher.java:44)
Caused by: java.io.FileNotFoundException: logs\MAIN_rfi_report_2021-04-23_21_15_
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.<init>(Unknown Source)
at com.rusefi.FileLog.openLog(FileLog.java:93)
at com.rusefi.FileLog.start(FileLog.java:55)
... 2 more
Shutdown hook...
Shutdown hook!
va console.exe
Error: Could not find or load main class console.exe
Your console does not have permissions to start writing logs. You can launch it under adminstrator or move it to a different folder?
I've made a software change to survive such scenario https://github.com/rusefi/rusefi/commit/6dab0a2916184e27c76c5060cf451eebed1f721e you can take latest 'nightly' build in about 20 minutes.
Thank you for a great error report!
Bingo! Just put everything in another folder and it now launches!Your console does not have permissions to start writing logs. You can launch it under adminstrator or move it to a different folder?
Well, I should thank you!Thank you for a great error report!
Another thing I've noticed : rusefi_simulator tends to get deleted if it encounters an error.
The two instances it happened :
EDIT : After tinkering with the console, it seems it will still open the simulator if I click on connect... weird...
- Before managing to make rusefi_console work, I just clicked on rusefi_simulator, it tried to execute something but then crashed (or just closed) and deleted itself.
- Now with rusefi_console, I launched the virtual simulator and randomly clicked on radiator fan or something like this. It opened a dialog box saying : no connectivity then closed itself and deleted itself (rusefi_simulator.exe)
Not quite there yet...
The console recognizes the MRE (on COM25) and makes it react when I try to update with the auto-dfu mode but it stops there and I get this :
Under device manager and in DFU mode, I have this :
And for the record, this under normal (non-DFU) mode :
I've tried (re?)installing the drivers via the rusefi_console but it makes no change...
Using selected COM25
Reboot command sent!
Giving time for USB enumeration...
Executing .\.\DfuSe/DfuSeCommand.exe -c -d --v --fn ..\rusefi.dfu
0 Device(s) found. Plug your DFU Device !
ERROR: Maybe DFU device not attached? Please check Device Manager.
ERROR: Maybe ST DFU Driver is missing?
ERROR: Maybe driver conflict with STM32Cube?
Target 00: Error Code: Unknown error 0x12340005.
Target: 00
TransferSize: 0
DFU State: (Unknown 0x75)
DFU Status: STATUS_OK
Request: (unknown 0x06416ABB).
CurrentNBlock: 0x0000
CurrentLength: 0xC8002579
Percent: 0
I have no idea what is this LibUSB-K PS2 I've never seen that before but please kill it with fire. There should be no LibUSB-K PS2 on device manager to update firmware.
Random internet link https://superuser.com/questions/227029/how-can-i-remove-libusb-on-windows-7/1149663
Thanks again
1 Device(s) found :
Device [1]: STM Device in DFU Mode, having [4] alternate targets
Duration: 00:00:01
Target 00: Upgrading - Erase Phase (12)... Duration: 00:00:01
Target 00: Upgrading - Erase Phase (24)... Duration: 00:00:02
Target 00: Upgrading - Erase Phase (49)... Duration: 00:00:02
Target 00: Upgrading - Erase Phase (49)... Duration: 00:00:03
Target 00: Upgrading - Erase Phase (61)... Duration: 00:00:03
Target 00: Upgrading - Erase Phase (61)... Duration: 00:00:04
Target 00: Upgrading - Erase Phase (61)... Duration: 00:00:05
Target 00: Upgrading - Erase Phase (74)... Duration: 00:00:05
Target 00: Upgrading - Erase Phase (74)... Duration: 00:00:06
Target 00: Upgrading - Erase Phase (74)... Duration: 00:00:07
Target 00: Upgrading - Erase Phase (86)... Duration: 00:00:07
Target 00: Upgrading - Erase Phase (86)... Duration: 00:00:08
Target 00: Upgrading - Erase Phase (86)... Duration: 00:00:09
Target 00: Upgrading - Erase Phase (100)... Duration: 00:00:09
Target 00: Upgrading - Download Phase (0)... Duration: 00:00:10
Target 00: Upgrading - Download Phase (2)... Duration: 00:00:10
Target 00: Upgrading - Download Phase (4)... Duration: 00:00:11
Target 00: Upgrading - Download Phase (5)... Duration: 00:00:11
Target 00: Upgrading - Download Phase (7)... Duration: 00:00:12
Target 00: Upgrading - Download Phase (9)... Duration: 00:00:12
Target 00: Upgrading - Download Phase (11)... Duration: 00:00:13
Target 00: Upgrading - Download Phase (12)... Duration: 00:00:13
Target 00: Upgrading - Download Phase (14)... Duration: 00:00:14
Target 00: Upgrading - Download Phase (16)... Duration: 00:00:14
Target 00: Upgrading - Download Phase (18)... Duration: 00:00:15
Target 00: Upgrading - Download Phase (20)... Duration: 00:00:15
Target 00: Upgrading - Download Phase (22)... Duration: 00:00:16
Target 00: Upgrading - Download Phase (24)... Duration: 00:00:16
Target 00: Upgrading - Download Phase (26)... Duration: 00:00:17
Target 00: Upgrading - Download Phase (27)... Duration: 00:00:17
Target 00: Upgrading - Download Phase (29)... Duration: 00:00:18
Target 00: Upgrading - Download Phase (31)... Duration: 00:00:18
Target 00: Upgrading - Download Phase (33)... Duration: 00:00:19
Target 00: Upgrading - Download Phase (35)... Duration: 00:00:19
Target 00: Upgrading - Download Phase (37)... Duration: 00:00:20
Target 00: Upgrading - Download Phase (39)... Duration: 00:00:20
Target 00: Upgrading - Download Phase (41)... Duration: 00:00:21
Target 00: Upgrading - Download Phase (43)... Duration: 00:00:21
Target 00: Upgrading - Download Phase (45)... Duration: 00:00:22
Target 00: Upgrading - Download Phase (47)... Duration: 00:00:22
Target 00: Upgrading - Download Phase (49)... Duration: 00:00:23
Target 00: Upgrading - Download Phase (51)... Duration: 00:00:23
Target 00: Upgrading - Download Phase (52)... Duration: 00:00:24
Target 00: Upgrading - Download Phase (54)... Duration: 00:00:24
Target 00: Upgrading - Download Phase (56)... Duration: 00:00:25
Target 00: Upgrading - Download Phase (58)... Duration: 00:00:25
Target 00: Upgrading - Download Phase (60)... Duration: 00:00:26
Target 00: Upgrading - Download Phase (62)... Duration: 00:00:26
Target 00: Upgrading - Download Phase (64)... Duration: 00:00:27
Target 00: Upgrading - Download Phase (66)... Duration: 00:00:28
Target 00: Upgrading - Download Phase (68)... Duration: 00:00:28
Target 00: Upgrading - Download Phase (70)... Duration: 00:00:29
Target 00: Upgrading - Download Phase (72)... Duration: 00:00:29
Target 00: Upgrading - Download Phase (74)... Duration: 00:00:30
Target 00: Upgrading - Download Phase (75)... Duration: 00:00:30
Target 00: Upgrading - Download Phase (78)... Duration: 00:00:31
Target 00: Upgrading - Download Phase (79)... Duration: 00:00:31
Target 00: Upgrading - Download Phase (81)... Duration: 00:00:32
Target 00: Upgrading - Download Phase (83)... Duration: 00:00:32
Target 00: Upgrading - Download Phase (85)... Duration: 00:00:33
Target 00: Upgrading - Download Phase (87)... Duration: 00:00:33
Target 00: Upgrading - Download Phase (89)... Duration: 00:00:34
Target 00: Upgrading - Download Phase (91)... Duration: 00:00:34
Target 00: Upgrading - Download Phase (93)... Duration: 00:00:35
Target 00: Upgrading - Download Phase (95)... Duration: 00:00:35
Target 00: Upgrading - Download Phase (97)... Duration: 00:00:36
Target 00: Upgrading - Download Phase (100)...
Upgrade successful !
Duration: 00:00:00
Target 00: Uploading (24)... Duration: 00:00:01
Target 00: Uploading (68)... Duration: 00:00:01
Target 00: Uploading (100)...
Verify successful !
Done!
SUCCESS!
Please power cycle device to exit DFU mode
