My name is Laurentiu and i'm from Romania, I'm a Systems Engineer that works as telecomunications engineer :p
I want to show you my test mule
Golf Mk2 originally 1.8 8v Monojetronic soon to start swapping in the 1.8T engine
Will add DB25 or DB37 connectors so i can test multiple ECUS and have cheap plug n play solution for swaping ecu's. The car will run MRE as main ECU and another board under development that I will not mention here (maybe will try Proteus also)
