Here is a video of a previous version that ran on a teensy 3.6. I've since moved to a ATSAME51G19 for the Mcan peripheral and all it's buffers, plus it's a M4, so it has floating point support for fast screen updates and easier data management. I am still using a 128*128 4bit greyscale display, but only single bit per pixel right now. All in, I think everything can be shrunk down to fit inside a 52mm gauge pod, although mine takes place of the stock oil pressure gauge in the NB2 gauge cluster for now. Not a lot of expensive parts, but I'm unfamiliar with JLPCB assembly and what they stock. I am some kind of masochist and still do stencils and hand placement...
The "stack" Power board, CPU board, display board, and LED board all sandwiched together!
But, I can fit some expensive parts on. I have used ublox's M8N, plan to try one of the new M9N's for the wicked 25Hz speed. A GPS lap timer would be cool, one with splits even better. I think I could set up a system where you'd press a button while moving on track to set a gate, then calculate when you cross that gate, pretty much what racechrono or similar does. A performance timer for testing tuning would be cool, too.
I've tried a few different MPUs and calibration methods and think I've got stuff within usable range with minimal drift, although no idea what to do with the data. I've added light sensing dimming, as well as tied into the low side dimmer circuit in a car so it will follow the dash dimmer and keep from blinding yourself at night. I've got a RTC and an external attiny powered off a battery connected LDO, to keep the GPS ready for hot starts and letting things shut down smoothly with fancy animations. It also currently feeds my megasquirt RTC data before the GPS fully boots, because 80+ bucks for a RTC board is madness and it doesn't properly label SD logs otherwise. Probably much, much better ways to do all this than the ways I've chosen!
What would be really awesome is if we could have some values be adjusted realtime via canbus. Say you were trying to tune a PID loop or warmup, accel enrich, etc. With an encoder to modify values and a live running histogram trying things in trouble areas without fretting with a laptop would be amazing! Tunerstudio allows canbus passthru for configuration, so you could "tune" the gauge for your display preference through the ECU, in theory at least.
If there is any interest I'll clean up the code and hardware files in the next few days and post them up.
Edit: I don't know why I put this in software, sorry!
