When you load the software in your board some presets are set.
À newbee doesn't know how it works and perhaps may not use always the correct package.
The result is some incorrect setup.
Whould it be possible to separate the software update from preset settings so a user can correct his error by applying the correct presets for his board?
How to set the presets for the different boards
JPh
Re: How to set the presets for the different boards
There's a button in Tunerstudio to reset to the configuration back to the defaults. The button is in the "popular vehicles" page. It will wipe all of your settings, but will restore it back to how a new board would be with that firmware.JPh wrote: ↑Thu Jun 11, 2020 4:05 amWhen you load the software in your board some presets are set.
