microRusEfi connection to Tuner Studio
It's all about the code!
JPh
Re: microRusEfi connection to Tuner Studio
Post by JPh »
W7
Yes I installed the drivers with the console
please try installing https://github.com/rusefi/rusefi_external_utils/raw/master/DFU_mode/DfuSe_Demo_V3.0.6_Setup.exe
manually maybe this would get drivers installed properly?
JPh
Post by JPh »
JPh
Post by JPh »
JPh
Post by JPh »
I found a way to install the missing driver. I installed it manually from the device manager.
You have to give the path : C:\Program Files (x86)\STMicroelectronics\Software\DfuSe v3.0.6\Bin\Driver\Win7
Post by Abricos »
Maybe You have so many old USB connections ...
Delete what you not used in Devices manager/universal serial bus controller.
JPh wrote:
Wed Mar 11, 2020 8:33 pm
And? Did you get to update firmware? is connection reliable now?
is your problem solved? :)
JPh
Post by JPh »
The firmware update was successful.
Now the connection with TS is stable.
I just asked a question on SLACK about the blinking red/green Indicator in the Bottom right corner of the TS screen.
It seems that the problem is the automatic install of the STM32 bootloader does not work.
JPh wrote:
Thu Mar 12, 2020 9:40 am
I must have missed it :( Can you please repeat here?
JPh
Post by JPh »
My red/green indicator in the bottom right is not steady green. It blinks red/green. So I asked if it is normal. Since then I made some test changes with TS and it burns correctly in mre so I think it is normal.
JPh
Post by JPh »
In your new video about programming you introduce the need to push the program button.
I didn't knew it when I program mine so I haven't done it but it worked!
JPh wrote:
Fri Mar 13, 2020 8:56 am
In my video I was doing initial first time programming which is also emergency-things-are-broken programming, first time even from the factory button usage is required, that's "Manual DFU"
Your programming is the good-case-normal-user programming "Auto DFU" it does not require the button.
JPh
Post by JPh »
Thanks useful information !
