Can someone explain what this setting is/does in Tuner Studio?
Please.
Analog Divider (coef)
NickZ
960
Re: Analog Divider (coef)
Good question!
This is the voltage-divider for the analog inputs.
Ideally this should be in the board-configuration, and be removed/hidden for users
stm32 has 3v ADC. most or all rusEfi boards have opamp input circuitry with a divider, often ratio is 2 or 1.67
960
Questions like this are really useful to see which things that makes confusion.
We can remove/hide these settings in TS, and set it in the board-configuration.
A user dont really need to change these settings
We have the mechanism to hide such settings from TS project, I've just done so for microRusEfi
https://github.com/rusefi/rusefi/commit/c553877d3d375a068a3e62ba58685dc51f142ecd
960
AndreyB wrote: ↑Sun Mar 01, 2020 2:22 pmWe have the mechanism to hide such settings from TS project, I've just done so for microRusEfi
Great
NickZ
so how to use it? i have used it to adjust for my voltage divider. if for example i have 5 volts divided down to 2.5 what would my setting be for a full scale 0-3v on the MCU.
what is the value the Analog Divider representing?
Just modified the description, new bubble description reads:
Ratio/coefficient of input voltage dividers on your PCB. For example, use '2' if your board divides 5v into 2.5v. Use '1.66' if your board divides 5v into 3v.Very limited telepathic abilities - please post logs & tunes where appropriate - http://rusefi.com/s/questions
