Jeep XJ 2500cc
matt
donator
donator
Jeep XJ 2500cc
Post by matt »
Hi all.
This is my friend Jeep Cherokee. Ecu got slightly burn at power supply circuit. I feel lazy to do repair on his ecu, so planning to make Rusefi running it. Something wrong with my phone, later I will upload actual picture.
Here is it look like:
I see Rusefi decoder is for 6 cylinder, mine is 4 and probably it trigger is look like this:
Can you guys make this new type decoder?
thanks.
Matt.
Re: Jeep XJ 2500cc
Re: Jeep XJ 2500cc
I think it's ready? See https://github.com/rusefi/rusefi/issues/615 for image, will update triggers list page later
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
Many thanks!!!
I will update how it goes.
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
Quite busy with life business, I hope I can start this Jeep by this weekend. I see trigger pic :-
Trigger offset is 484, so it is a rough number or solid?
Re: Jeep XJ 2500cc
TdcPosition is trigger oen business. You should use trigger offset zero.
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
Consider my next project for BMW E30, what do you guys opinion about Aliexpress Max9926? Seller state it is original Maxim chip.
Re: Jeep XJ 2500cc
matt wrote:
Mon Nov 12, 2018 3:06 am
I am pretty sure these are fake or not exactly OEM quality, but could work good enough for our purposes
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
Working on this car again, I see most of its wiring got slighly burn mark (wire insulation melting everywhere). Currently I change trigger to 16-1 running at cam speed. Do Rusefi support this?
Re: Jeep XJ 2500cc
just skipped wheel 16-1 on cam? yes for sure
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
Not much fund I got from this car owner. I do the trigger wheel which is very low cost. So this should work?
Re: Jeep XJ 2500cc
Yes that should be able to be decoded.
Re: Jeep XJ 2500cc
I do not understand the picture above. Which part is the wheel? Where is the gap? Where is the sensor?
matt
donator
donator
Re: Jeep XJ 2500cc
Post by matt »
russian wrote:
Thu May 02, 2019 1:21 pm
Test with ms2= too much lost sync
Test with Speeduino= too much lost sync
Rusefi= Not yet, will do in next few day
