[info] debugging - eclipse toolchain
It's all about the code!
Setting up debugging with Eclipse toolchain is a nightmare.
We would need
1) Eclipse
2) GDB - TODO an explanation what is the role of GDB
3) OpenOCD - "on chip debugger", the lowest-layer of debugging interface.
Useful links:
http://hertaville.com/2012/09/16/part-3-debugging-openocd-0-6-0/
(sorry this one is in Russian) http://makesystem.net/?p=2146
Re: debugging - eclipse toolchain
Step 1: installation
Download OpenOCD and start stm32f4 configuration like
openocd -f interface/stlink-v2.cfg -f target/stm32f4x_stlink.cfg -c init -c reset
run_openocd.bat
OpenOCD windows binaries are available here
Configure 'Debug' as on these pictures:
http://i.imgur.com/plS8JMt.png
http://i.imgur.com/K0j34v4.png
http://i.imgur.com/hY5rdKn.png
http://i.imgur.com/pgc00mg.png
http://i.imgur.com/zo6K9DG.png
http://i.imgur.com/Irv4xFZ.png
http://i.imgur.com/kRgapgT.png
jedediah_frey
Post by jedediah_frey »
Checkout ChibiStudio. It's a very nice packaged Eclipse setup for ChibiOS, GDB, OpenOCD and GCC.
acab
provoker
provoker
Post by acab »
if somebody use J-Link Debugger see that - http://gnuarmeclipse.livius.net/blog/jlink-debugging/
Just a note for myself: debugging works fine with 5.4_2016q3 version of everything and open OCD 0.9.0 as long as I point at the correct version of arm-none-eabi-gdb.exe
Using arm-none-eabi-gdb.exe from the wrong version does not help things :)
Also just tested and 7 2018-q2-update works as well.
One little annoying issue with some F7 chips - they have silicon errors causing default software breakpoints to not work. OpenOCD is kind enough to show relevant error message "Warn : Silicon bug: single stepping will enter pending exception handler!"
In order to use openocd and debug F7 you need to change break point breakpoint type from default to "hardware"
See also http://www.chibios.com/forum/viewtopic.php?f=16&t=4912
