MAP not showing any value
It's all about the code!
Snake____1
Post by Snake____1 »
Hi there,
Any suggestions on why the MAP value isn't showing up?
I have tried both PA0 and PA7 for comparison. @2.63v the MAP value is reading 0. On floating in a noisy 50hz enviroment MAP value bounces around 56kpa.
Just downloaded the new firmware 20180104_1855 and still no value.
(X) BMW E36 318i M50B50 Turbo (MegaSquirt (KdFI v1.3))
(X) BMW E36 325tds M70B50 (ViPEC V88)
(X) BMW E36 328i M52B28 Turbo (rusEFI PnP @me)
(✓) BMW E36 320i M70B50 (rusEFI project car)
(✓) BMW E46 325Xi M57D30 (daily)
Re: MAP not showing any value
please post
mapinfo
and
analoginfo
output from console
Snake____1
Ah, I see! But it's limited to 250kpa... What does this limitation correlate to?
2018-01-06 01_45: EngineState: confirmation_mapinfo:7
2018-01-06 01_45: EngineState: instant value=256.08kPa
2018-01-06 01_45: EngineState: map type=0/MT_CUSTOM MAP=0.00kPa mapMinBufferLength=1
2018-01-06 01_45: EngineState: MAP 2.13v @PA0
2018-01-06 01_45: EngineState: at 0.00v=0.00 at 5.00v=300.00
2018-01-06 01_45: EngineState: WARNING: unexpected MAP value: 256.08
2018-01-06 01_45: EngineState: confirmation_analoginfo:10
2018-01-06 01_45: EngineState: analogInputDividerCoefficient: 2.00
2018-01-06 01_45: EngineState: fast enabled=Yes
2018-01-06 01_45: EngineState: hip9011 ADC10 fast PC0 adc=0.20/input=0.41v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for fuel gauge
2018-01-06 01_45: EngineState: TPS ADC2 slow PA2 adc=0.00/input=0.00v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for pPS
2018-01-06 01_45: EngineState: CLT ADC12 slow PC2 adc=2.29/input=4.59v/divider=2.00
2018-01-06 01_45: EngineState: IAT ADC11 slow PC1 adc=2.29/input=4.58v/divider=2.00
2018-01-06 01_45: EngineState: AFR ADC13 slow PC3 adc=0.00/input=0.00v/divider=2.00
2018-01-06 01_45: EngineState: MAP ADC0 fast PA0 adc=2.13/input=4.26v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for OilP
2018-01-06 01_45: EngineState: ADC is not assigned for A/C sw
2018-01-06 01_45: EngineState: HIP9011 ADC10 fast PC0 adc=0.20/input=0.40v/divider=2.00
2018-01-06 01_45: EngineState: Vbatt ADC14 slow PC4 adc=0.98/input=8.49v/divider=8.60
250kpa is a lot of forced induction! What units do you speak?
normal atmosphere should be 100kpa give or take.
Snake____1
russian wrote:250kpa is a lot of forced induction!
Yeah, I know. Hehe...
300kpa = 2bars of boost.
I have a 3bar MAP sensor. I might swap it out for a MPXH6400A "4bar" over time. Running 1.5bars of boost isn't to uncommon for a forged engine :roll: So I would like to try 2bars at another date :mrgreen:
Maybe you should add a customizeable maximum MAP value? :D
Snake____1
Also note, the VE table almost looks inverted for some odd reason... Any Idea as to why?
Snake____1 wrote:Any Idea as to why?
Because certain areas were self-tuned for longer than others, while some areas were never touched? (see the green and red maps on the right)
Lyonz
kit assembler
Post by Lyonz »
Hi,
I take this post to ask a question.
What is the maximum pressure that rusEFI can handle?
Because I am preparing a car file for drag, and I am aiming for a maximum turbo pressure of 340 to 350kpa.
But I do not understand why I can not put values above 300kpa
No reason, will change limit to 500kpa :)
Post by Abricos »
What is your MAP sensor maximum pressure hold ???
Model of your MAP sensor ??? PDF !!!
Lyonz
kit assembler
Post by Lyonz »
Abricos wrote:
Fri May 04, 2018 6:20 pm
Hi, I have this one MPXH6400 => 400 kpa
For this race car, I will try 340 or 350 kpa
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Fri May 04, 2018 4:29 pm
Thanks a lot...
https://github.com/rusefi/rusefi/commit/ee3e6c1eaf53b97cfc2266a974075d6e777280da
I will try soon
Peugeot 1.6 16v with gtx3071r for dragrace.
Hop more than 450hp for the moment.
Pics & video soon
One question, I would like to know if LC & NLS work?
