For simplicy of troubleshooting I like to split the ECU hardware into two pieces - a board with just the CPU (brain board), and the input-output board, also known as main board.
discovery is an off the shelf brain board. rusEfi also has it's own brain board, both are the same thing
Main board is also known as "discovery shield" if you look at the main board as something which allows a discovery board to act like an ECU.
Yes we use external MAP sensors. I am expecting to get assembled boards back in stock in about three weeks.
Are the only differences between Frankenstein and Frankenso the size of the board? i.e. do they have the same capabilities? The only reason I'm asking is because my car has Bosch LH2.4 and I have several spare ECUs kicking around that I could use for the case and connector.
Has Speeduino run a V8 with COP? I think you are limited in your IO, and might not have enough to do it. If you go speeduino I would double check that you have enough IO before you go to far. The discovery board uses a 32 bit ARM chip which is a much faster bit pump than the 8 bit AVR used by Arduino's. As well ARM processors consume about 70% to 80% of all embedded applications. This is mostly caused by cell phones and tablets. So they are going to be around for a long time. I understand the AVR's used by Arduino's have been ported to ARM based chips, so if something happens to AVR's you'll most likely still have options. However most ARM's are 3.3V not 5V, so porting over might be a hardware bugger.
Frankenso was updated such that it could provide 8 channels of ignition signals. However Frankenstein did not get this updated, and can only do 6 channels of ignition. I fear you would either not have enough ignition channels with Frankenstein, or you would have to wire them simulating wasted spark. You can avoid this kind of drama if you use a Frankenso board.
I would suggest a Frankenso. I know it has enough IO to do what you want with a V8. The salvage yard ECU's are reasonably low cost to obtain. It has 12 low side channels, which is handy as you can have 8 injectors, plus 4 other devices. Think radiator fan, fuel pump relay, idle solenoid, tach signal, etc.
Frankenso it is, then. Thank you for explaining it all to me. The donor Jag arrives today, so as soon as Christmas is out of the way I can start to strip it and get the engine mounted in the Volvo
