I'm trying to figure out what the LCD display is showing and I'm not too sure where to go to manipulate it. Has someone posted how to do such? This counter counts up to 300n and then the board resets, not sure if it has something to do with when I put it together or if it's a software thing.
PS: do not see power supply LED on the videos. How is everything powered on this video? Do you have same result if powering the board with 12 volts? The way the video is I am not sure if there is a mini USB cable there?
Here is a video of it with power to the board with the USB and 12v power supply turned on. It does the same thing at the sae time interval. Looking at the logs it doesn't show any sort of "oh crap, disconnect" it just resets as if it is losing the com port. But even with it not plugged in it does the same thing. It could be an ECU thing yes, I went with LCD because that's what I was noticing of course.
I have to say I have no idea what could be causing this. Does it happen with only 12v power supply and with both USB cables disconnected? I am trying to eliminate any console or PC magic in general.
