I will have plenty of projects going shortly and if I can successfully make this work I will be buying a couple of ECUs for projects, one will be a small 250cc motorcycle, a big 1100cc drag/cruise bike and most notably a Foxbody Mustang that we will be trying to get into the 8's with. As far as I know nobody has done any high HP builds on RusEFI. The fox will be in excess of 1000hp on a turbo Chev LS, with any luck the motor will be built next year and a RusEFI system will be running it (If anybody sees any limitation in the hardware in regards to this feat please let me know ASAP). I'm new to coding, soldering, and messing around with systems in general, I have experience with Carbs...that's it. but if you guys are interested in seeing this thing run feel free to lend a helping hand (trust me, it will be needed) technically or even on the car itself if you're in the Toronto area. Also, if you are in the Toronto area give me a shout if you need help or sandblasting.
At any rate, I will be asking many questions over the next year as I build things and stuff; I hope that it works well and that we can maybe even getting things like nitrous control, launch control via trans brake and all the racing things going.
