Opel Corsa B, 1.8L
juanj
Opel Corsa B, 1.8L
Post by juanj »
hi guys , after a long wait finally I have the frankenso board in my hands :D :D and I started welding work.
-the board power supply work fine, tested.
-load the firmware successful in the smt32 board.
-the rusefi console connection work.
but i have many questions, whats it is the communication port for TS? i can use the smt32 microusb for this purpose? or only is possible by microusb TTL frankenso board?
i tried connection TS but an error message appears. :?: :roll:
thanks, help me
Re: Opel Corsa B, 1.8L
Cool :)
Soldering paste maybe? See http://rusefi.com/forum/viewtopic.php?f=4&t=425
Yes you can run TS via microUSB: you need to put a jumper on GND and PB1 pins & reboot stm32
See also http://rusefi.com/wiki/index.php?title=Manual:Software:TunerStudio_connectivity
See also http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#Communication_mode
juanj
Post by juanj »
yes i use soldering paste, its the best method.
i'll try.... ;)
juanj
Post by juanj »
thanks russian :) :) :) :) TS work perfect!!!
Time for more pictures :)
One thing about the LED screens: they come from different suppliers and looks like they want different contrast resistor. One style needs 2K and another style needs 1.5K
Right now I've forgotten which one wants what value :( Looks at the traces and vias on the LCD pcb to see the difference.
juanj
Post by juanj »
hi, :D i try which 2k and 1k now.
Your settings looks right, great job putting everything together!
I believe I saw the same thing when my contrast resistor value was off. At some point I was actually considering asking Jared for a small tiny potentiometer instead of that resistor but I am not sure.
juanj
Post by juanj »
thanks! a small tiny potentiometer is a good idea ;) , i try other resistor value :|
juanj
Post by juanj »
yeahhhhhh :D :D :D :D i put a 10k pot and works great...
[video][/video]
Magic :)
Can you please take a good picture of the whole board so that we know where you are exactly? Once you are ready I guess next step would be decoding your trigger signal. See http://rusefi.com/wiki/index.php?title=Manual:Hardware_Trigger
Please note that I am currently changing a lot of stuff related to console and tuner studio under https://sourceforge.net/p/rusefi/tickets/157/ so connectivity could be a bit unstable for the next week.
juanj
Post by juanj »
hello guys ,step by step, the tach imput is ready now :) ... i tested on a jimstim to generate 60-2 signal. the next step should be to check the analog imput and ignition/injection output.
here a picture of my board:
http://rusefi.com/wiki/index.php?title=Manual:Hardware_Test_Mode could be helpful to test the board. I also like the LEDs on the outputs, they blink really sexy...
This is a bit scary to me - is that a piece with naked +12?
juanj
Post by juanj »
hi, this is 12volt source. i put in the fuse place for board test only :D
How is it going? Is there anything I can help you with?
Do you know your car trigger signal shape already? Is it 60-2 or something else?
juanj
Post by juanj »
hi :D ,thanks, yes its 60/2 vr , the board is ready to test in my car, all circuit are tested (ign, inj, sensors and tach in). I can wait to replace headcam gasket :( .Unfortunately broke last week. the next week will be ready to start..
