Just tried the paper test and realized that the connectors I've got from China has a bit different footprints:
On the bright side, both rows of pins look right. On the other side, the rows are a bit closer, and there is that 3rd row of seven groups of three pins which are all connected together - some kind of mega-ground I guess. Also the mounting holes are located differently.
I will later try to find the datasheet for this version of the connector I've got.
still can't understand if it is just one piece with wires or two pieces: with wires and with legs to be mounted on board.
btw, what's the estimated shipping cost?
puff wrote:still can't understand if it is just one piece with wires or two pieces
What part of 板插头线束 M154 55针 do not you understand? This is just the plug with the wires, the header is a separate item. At least that's the way I understand it.
I've used engtaobao.com and shipping and service fee has more or less doubles the price.
