I downloaded the source and tools needed to compile resefi.hex and updated the relevant mx5 configuration file to reflect my i/o assignment.
After loaded the new hex I did some basic testing and tried to start car! There were a few ignition pops on the first try but none on subsequent tries. It looked like like no fuel was getting to the rail.
It turns out that OUT1 (where I have the fuel pump connected) needs a zero ohm resistor on the board to become active. I added the jumper and tried again. The results were a bit better with several ignitions occurring in a row. I adjusted the cranking fuel pulse width command and changed the global trigger offset angle a little but soon after my battery died.
Is there a console command that can be used to energize/toggle the coil channels for a short duration?
Also commands for toggling other outputs like fuel pump and injector channels would be useful when initially testing.
The learning experience continues.
