For ITB, you may find MultiMap of use, https://github.com/jharvey/MultiMAP it combines several MAP signals and reports the lowest signal to the ECU. I understand often people try to do this with hoses and check valves. Doing this electronically is faster and has a better response time. There are some mild issues, basically diode selection could be better, but it works as as is.
