Suzuki G13BB Trigger
FFG_Garage
Post by FFG_Garage »
Hello!
I would like to use rusefi with an old suzuki swift, G13BB engine code. I found the supported trigger page hase the G13B patter, but in this suzuki a little bit different the trigger wheel. It is in the distributor with a VR sensor, and hase 3 tooth for every cylinder. 91 degree, 61 degree and 6 degree before TDC. The factory manual write this:
Can somebody add this trigger to the rusefi code? or is any documentation how can I add it?
thank you
FFG_Garage
Re: Suzuki G13BB Trigger
I modified the trigger_suzuki.cpp file to this in my custom firmware:
void initializeSuzukiG13B(TriggerWaveform *s) {
	s->initialize(FOUR_STROKE_CRANK_SENSOR, SyncEdge::RiseOnly);
	int w = 5;
	s->addToothRiseFall(95, w);
	s->addToothRiseFall(125, w);
	s->addToothRiseFall(180, w);
	s->addToothRiseFall(275, w);
	s->addToothRiseFall(305, w);
	s->addToothRiseFall(360, w);
  s->tdcPosition = 180 + 6;
	s->isSynchronizationNeeded = false;
	s->shapeWithoutTdc = true;
with this mod it working on my table, drive with an old jbperf stimulator board. I will test it with in a real car.
Please explain what's going on here
We do not have this trigger at all?
We have the trigger but it's broken?
Something else?
Do you have a logic analyzer recording of this signal flow? Maybe using a $9 eBay logic analyzer?
FFG_Garage
I try to explain it:
The suzuki G13B hase a 12 tooth trigger whell in it's distributor, in my first post I uploaded an image from the factory service manual. this is some other photos from it:
In the supported triggers page hase a trigger with name G13B, but this is not the factory suzuki G13B trigger (I think someone made a trigger decoder from the modified trigger whell, because for example Haltech is supported only suzuki G13B with a modified trigger wheel, need to cut off some tooth)
I found this picture in Haltech support page, this wheel is a modified one, 4+1 style trigger:
In the original rusefi firmware is supported this modified trigger wheel (cutted some tooth).
with my code, my custom firmware now work with the factory 12 tooth wheel (real car testing will need)
the current rusefi firmware G13B pattern:
this is not a 12 tooth pattern, this is a 4+1
